  I need a special part
I need a special part by Daryl M
Started on: 01-07-2019 03:39 PM
Replies: 8 (287 views)
Last post by: Daryl M on 01-08-2019 02:15 AM
Daryl M
Report this Post01-07-2019 03:39 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
am looking for a blocking plate similar to this with the following dimensions:
68mm wide
40mm tall
50mm bolt hole spacing
8mm bolt holes
Thickness not critical
This will be to block ports used to pump air into the exhaust to meet California emissions. I am deleting that. Anyone have ideas on a place to get these?
Thanks
Daryl
[This message has been edited by Daryl M (edited 01-07-2019).]
Spoon
Total ratings: 61
Report this Post01-07-2019 07:11 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check this link.
https://www.ebay.com/sch/i....plates&ul_noapp=true
If no luck just grab a piece of metal at Home Depot. All you need is a vise, jigsaw, and a drill.
Spoon
paced84
Report this Post01-07-2019 08:11 PM Click Here to See the Profile for paced84Send a Private Message to paced84Edit/Delete MessageReply w/QuoteDirect Link to This Post
go to ebay Fiero powder coated
Ron T
signature by F-I-E-R-O (My Indy on right / #1 IMS)
Daryl M
Report this Post01-07-2019 08:59 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Two things I should have mentioned.
1 I have spent hours on eBay/other sites with no luck.
2 this is for the LFX engine I am swapping into my 88 so fiero parts won't fit.
Thanks for the suggestions anyway.😁
Daryl M
Report this Post01-07-2019 09:11 PM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Member since Aug 2016
This is what I want to block off.
Report this Post01-07-2019 10:36 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If that pump was only used on the California emissions applications, then there might be a GM block off plate for it when they didn't need to install the pump (possible export applications too).
Do you have a picture of the pump flange that was removed?
Have you checked the ID of the hole to see if there is a freeze plug in that size?
[This message has been edited by fieroguru (edited 01-07-2019).]
Daryl M
Report this Post01-08-2019 02:00 AM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Actually GM just didn't machine the opening for the non-California version.
Daryl M
Report this Post01-08-2019 02:07 AM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Well, I took Spoon's advice and made a couple from some aluminum I had sitting around. Not exactly CNC quality, but they should work. Ironically, I spent more time looking online than it took to make them.
[This message has been edited by Daryl M (edited 01-08-2019).]
Daryl M
Report this Post01-08-2019 02:15 AM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
Daryl M
Thanks everyone for your comments.
