You have the as cast geometry, but then after being machined to spec and assembled, the balancers are balanced to spec (neutral or with some imbalance) normally by drilling additional holes along the outer perimeter, but I have seen people mill of cast in weights as well.
With it being such a small as cast boss, and as purchase volumes declined, they likely chose to use one standard casting (possibly with the boss) to save on mfg cost and just balance them as needed to meet the appropriate spec (neutral or with an imbalance)
Even in the picture in the article where they refer to the balancer as being neutral balanced, you can see the boss, but you also see the balance holes on the same half of the balancer as the boss, which likely helps make it neutral balanced.
The amount of imbalance you introduce is the mass of the weight (or lack of weight = hole) x the distance from the crankshaft center-line. So with this very small boss being a couple of inches from the center of the crankshaft, the imbalance it creates is very, very small.
To put the potential imbalance into perspective, the 400 SBC was externally balanced at both the balancer and flywheel. Look at the size of the weight inside the balancer for it. It could easily be 50 times larger than the tiny boss on the 2.8 one.
So for the 2.8, buy the balancer from a reputable supplier for your specific application and move on...
[This message has been edited by fieroguru (edited 01-05-2019).]
