According to the VIN, I've got a 94 Eldorado Northstar that I plan on using for parts and eventual rebuild (time-serts/head bolts).
I pulled the motor and transmission from the car, leaving the cradle so it could still be towed away to the scrap yard. I had found only one pry point between the two, but they weren't coming apart. So, I just loaded both and took it all home.
So, I started yesterday with the goal to separate the transmission from the motor. I confirmed that all of the bolts were out. Then, with a 5lb sledgehammer and a few well-placed punch rods, I started to see daylight between the block and transmission. I was able to work an old wood chisel into the gaps that then allowed room for me to use the prybar.
It all now wiggles as it should, with exception to the connection point at the bottom left ("A", if you are using the illustration in this thread:
https://www.fiero.nl/forum/Forum2/HTML/000182.html URL for actual picture:
http://images.fieroforum.co...using_Bolt_Holes.jpg ).
The bolt of course is out, but the bell housing and block seem to be fused together right at that point.
Is the solution to just dowse it in penetration fluid and let it sit for a few days. Or, am I missing something here?
