  Tutorial on removing/replacing driver side coolant pipe on 85 SE
Tutorial on removing/replacing driver side coolant pipe on 85 SE by hcforde
Started on: 12-19-2018 03:35 PM
Replies: 9 (359 views)
Last post by: Will on 12-24-2018 08:54 PM
hcforde
Report this Post12-19-2018 03:35 PM Click Here to See the Profile for hcfordeSend a Private Message to hcfordeEdit/Delete MessageReply w/QuoteDirect Link to This Post
any suggestions on how to remove these?
Report this Post12-19-2018 05:25 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Unless you have access to a single point/post lift, you can't from old posts here. (Other lift types can block the pipes.)
Maybe not even first removing plastic spare tire well/wall.
You need to lift the car high to get clearance in front.
Notes:
Pipe(s) have two brackets you see easy and a stud w/ nut near radiator hoses in front.
There is a brake line attach to tire wall.
[This message has been edited by theogre (edited 12-19-2018).]
hcforde
Report this Post12-20-2018 11:01 AM Click Here to See the Profile for hcfordeSend a Private Message to hcfordeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Notes:
There is also some type of clamp holding it down under the tire well. What were they thinking??? Looks like they figured it out better on the 88's.
Report this Post12-20-2018 01:08 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
The interference point is at the back of the DS LCA.
The car needs to be raised high enough to work it out.
The front tub must be removed.
hcforde
Report this Post12-20-2018 05:18 PM Click Here to See the Profile for hcfordeSend a Private Message to hcfordeEdit/Delete MessageReply w/QuoteDirect Link to This Post
DS???
LCA???
Report this Post12-20-2018 06:26 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Driver side lower control arm....
Spoon
Total ratings: 61
Report this Post12-20-2018 09:58 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check Rodney Dickman's site. He has a kit for removing that coolant pipe. You cut it before it goes up over the suspension and use his kit to put things back together,,, if you don't mind the patch.
Spoon
hcforde
Report this Post12-21-2018 10:22 PM Click Here to See the Profile for hcfordeSend a Private Message to hcfordeEdit/Delete MessageReply w/QuoteDirect Link to This Post
I attempted to MIG/fluxcore weld it but ended up blowing through because it was thin in the first place and the split made it more vulnerable. So I did cut the tubing by the suspension and found a radiator hose that mimicked the turns at the proper places. Put them all in place loosely today and will tighten them all down Sunday double clamping at both ends.
Report this Post12-21-2018 11:32 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
πŸ‘πŸΌπŸ‘πŸΌ
Total ratings: 236
Report this Post12-24-2018 08:54 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
Everything ELSE in this thread is WRONG.
Once the bolt attaching the pipe to the front suspension crossmember is out, you can R&R the coolant tubes WITH THE CAR ON THE GROUND. I've done it. You need a good bit of room to the sides, though.
-Park the car on a flat, level surface
-You MUST remove the front tub. That takes ~20 minutes your first time and 5-10 thereafter.
-Remove the small bolt attaching the tube to the crossmember
-Drain the cooling system
-Disconnect the hoses at each end of the tube
-Remove the clamps holding the tube to the underbody
-Swing the tube out to the side and thread the front section around the front suspension
-Remove the tube
Do the opposite to reinstall.
Since the stainless socket drain plugs frequently round out, I replace them with external hex brass drainplugs as well.
[This message has been edited by Will (edited 12-24-2018).]
