  Window washer not spraying?
Window washer not spraying? by Spadesluck
Started on: 12-10-2018 10:02 PM
Replies: 2 (90 views)
Last post by: Gall757 on 12-11-2018 10:06 PM
Spadesluck
Report this Post12-10-2018 10:02 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
When I try to activate the washer on the stalk it does not spray. The wipers do work on all modes int, low and high. It does not get any voltage at the washer when activated. I did test the washer by itself with the battery and it does spray. Could this be something in the column?
Spadesluck
Report this Post12-11-2018 06:07 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Never mind, I am a dummy. Was hitting the mist while testing the washer motor. Clearly was not the correct way to do so.
[This message has been edited by Spadesluck (edited 12-11-2018).]
Report this Post12-11-2018 10:06 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
That was going to be a difficult problem to trouble shoot.....
