| quote | Originally posted by Gall757:
Make sure the connections on the battery cables are clean. Both ends....use a wire brush. The cables could be corroded internally. |
After that, if you have insured that your battery is good and fully charged:
1. Check for fault codes
2. Check for fuel pressure and put fresh gasoline in the tank
3. Check for spark and for mouse damage on the wires.
