  1985 2.5 fuel pump
1985 2.5 fuel pump by Lou6t4gto
Started on: 11-28-2018 07:05 PM
Replies: 4 (470 views)
Last post by: Lou6t4gto on 11-29-2018 05:57 PM
Lou6t4gto
Report this Post11-28-2018 07:05 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
Am I correct in that a" fuel pump" for a 1985 2.5, and a 1985 2.8 Fuel pump are Different ?? I am seeing many Ads that say the same pump fits Both ! I need to know the truth of the matter Before I order one. Thanks
Report this Post11-28-2018 08:23 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Max PSI for the 4 cylinder (2.5) pump is 15 lbs. The V6 (2.8) pump is about 40 lbs..
[This message has been edited by Gall757 (edited 11-28-2018).]
Lou6t4gto
Report this Post11-28-2018 10:52 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
thats what I thought. thanks
Total ratings: 568
Report this Post11-29-2018 04:44 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ebay etc vendors are lairs claim this.
4 cyl engine can have problems w/ 6 cyl pumps because can slam regulator wide open and still be too high pressure.
4cyl are regulated to 9-13psi and less gas flow needed vs 6 or 8 high pressure systems.
If you buy them then must check system pressure at minimum.
Lou6t4gto
Report this Post11-29-2018 05:57 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
will Not buy from them
