| quote | Originally posted by Gall757: keep an eye on the oil level for a while. When engines get REALLY hot, they stop, and many times survive that with no problems. |
that you can see...
Engines get so hot enough to stop will have problems and may not show right now.
Pistons have seized from heat have big wear problems even crack skirts and Rings are weaker or even broken too.
Even if not burning oil, often have more blow by to crank and less power after baking the rings even without engine overheating to stop working.
Belt(s) broke are 1 or both main things:
Belt installed too tight or lose.
Driven items, alt and WP here, have problems.
See my Cave,
Serpent Belt V belts have most of same problems and tension data there.
