Click here to visit The FieroStore | View all sponsors
  Heater Corr remove and replace???
Heater Corr remove and replace??? by kevin
Started on: 11-26-2018 09:41 AM
Replies: 10 (167 views)
Last post by: Lou6t4gto on 12-03-2018 07:14 PM
kevin
Report this Post11-26-2018 09:41 AM Click Here to See the Profile for kevinClick Here to Email kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Fellas,
I need to remove and replace my heater core. I heard that one could remove and replace the heater core WITHOUT having to remove it from under the (passenger side) dash? Is that correct? In other words, you can remove it from the front? [removing sundry bolts, etc. from the area near the spare tire] I did my search on the Forum but could not find anything? Any ideas?
Cordially,
kevin
Ps. I have the Pontiac sub-speaker near my heater core. Therefore, with all that extra hardware, I fear that I will have to pull out my entire dash to get at it from the inside πŸ˜–
Total ratings: 313
Report this Post11-26-2018 09:53 AM Click Here to See the Profile for Dennis LaGruaClick Here to Email Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
To replace the heater core the heater box must be opened and removed. Its not a difficult job
kevin
Report this Post11-26-2018 10:06 AM Click Here to See the Profile for kevinClick Here to Email kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks Dennis,
I understand it is not that difficult of a job, ihowever, is time consuming, I simply do not want to pull the dash apart to get to the heater core from the inside 🀬, Any additional thoughts?
Cordially,
kevinn
Total ratings: 85
Report this Post11-26-2018 10:14 AM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
The core comes out without removing the dash. A/C cars are different.
Fiero Heater Core Replacement
[This message has been edited by Gall757 (edited 11-26-2018).]
USMUCL
Report this Post11-26-2018 12:48 PM Click Here to See the Profile for USMUCLSend a Private Message to USMUCLEdit/Delete MessageReply w/QuoteDirect Link to This Post
Kevin, you're under the wrong impression, I think. From underneath the dash, it's not bad at all.
Assuming you have A/C, it must be done from under the dash. Probably won't take an hour start to finish -- especially if you don't have to remove a subwoofer.
Mickey_Moose
Total ratings: 141
Report this Post11-26-2018 01:48 PM Click Here to See the Profile for Mickey_MooseClick Here to visit Mickey_Moose's HomePageClick Here to Email Mickey_MooseSend a Private Message to Mickey_MooseEdit/Delete MessageReply w/QuoteDirect Link to This Post
It is way more work to replace it via the front trunk (especially if you have AC).
kevin
Report this Post11-26-2018 07:43 PM Click Here to See the Profile for kevinClick Here to Email kevinSend a Private Message to kevinEdit/Delete MessageReply w/QuoteDirect Link to This Post
You are correct πŸ˜–,
Fellas,
I was hoping that I would NOT have to take the whole dash apart. 😟. Obviously, this was the origins of my question. Be that as it may, here I go😐........ grab my torx bits, Phillips screw driver and a flat head screwdriver. My Fiero will undergo a mild, ever so slight β€œsurgery” to repair said Heater core.
Cordially
kevin
mmeyer86gt/gtp
Total ratings: 70
Report this Post11-26-2018 07:52 PM Click Here to See the Profile for mmeyer86gt/gtpClick Here to Email mmeyer86gt/gtpSend a Private Message to mmeyer86gt/gtpEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have done this many times without removing the whole dash takes about 1 hour to r and r a heater core.
gtoformula
Report this Post11-26-2018 08:00 PM Click Here to See the Profile for gtoformulaClick Here to Email gtoformulaSend a Private Message to gtoformulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've replaced two Fiero heater cores as well as several other makes/models of cars. The Fiero is the easiest heater core that I've ever replaced.
Total ratings: 313
Report this Post11-26-2018 10:51 PM Click Here to See the Profile for Dennis LaGruaClick Here to Email Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
All my Fieros have A/C and I replaced two heater cores Its just a matter of disconnecting the hoses removing the screws opening the box , unfastening and removing the core downward toward the floor. You do not have to remove the dash and its not an involved process.
Lou6t4gto
Report this Post12-03-2018 07:14 PM Click Here to See the Profile for Lou6t4gtoClick Here to Email Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
have done it many times. the biggest pain is 1 screw that has to be gotten to though the top (Remove speaker cover) and use a long extension. there is no reason it cannot be done is less than an hour.
