  Right turn signal won't flash
Right turn signal won't flash by treborerellim
Started on: 11-25-2018 07:34 PM
Replies: 4 (146 views)
Last post by: theogre on 11-27-2018 01:40 PM
treborerellim
Report this Post11-25-2018 07:34 PM Click Here to See the Profile for treborerellimSend a Private Message to treborerellimEdit/Delete MessageReply w/QuoteDirect Link to This Post
If I turn on my left turn signal it flashes just fine. If I turn on the right turn signal all the bulbs light up but they won't flash. If I take the turn signal lever and repeatedly push it to the 1st stop the turn signal lights will flash. Any idea where I should start looking for the answer for this problem. Appreciate any help provided.
Thanks, Bob
Report this Post11-25-2018 08:27 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Check to see if the rear light works also. Even if the right front bulb is on, I would replace it.
Total ratings: 568
Report this Post11-26-2018 10:47 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Light(s) on often means little... Lights can be on and still have a crap ground.
See my Cave, Sneak Path
treborerellim
Report this Post11-27-2018 11:18 AM Click Here to See the Profile for treborerellimSend a Private Message to treborerellimEdit/Delete MessageReply w/QuoteDirect Link to This Post
Thanks for getting back to me. To answer Gall's 757s answer, I did replace both front and rear bulbs and also both side bulbs and it didn't seem to help. As to Ogres answer, I'm going to run that down because I had the front end replaced do to a minor accident. Hopefully I'll be able to find a bad ground there. Will post more when I know more.
Bob
Total ratings: 568
Report this Post11-27-2018 01:40 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
front and/or rear sockets can have iffy ground w/ New bulbs. So don't think new bulbs = good connection in the sockets.
