  5 speed reversed
5 speed reversed by shemdogg
Started on: 11-23-2018 12:17 AM
Replies: 2 (230 views)
Last post by: shemdogg on 11-23-2018 04:40 PM
shemdogg
Report this Post11-23-2018 12:17 AM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
What would it take to reverse the gears in a transmission so the engine/tranny in a swap could be rotated 180 degrees? Like engine mans audi- the engine/trans position have to be the same so the front of his engine faces the firewall. The ferrari f40 has the longitudally mounted (I think its called) motor but the belts face the back of the car. If I did that swap that way id have 5 reverse gears and 1 forward gear.
Dunno much about transmissions obviously lol
Just thinking crazy/dreaming
whatchall think?
shem
Report this Post11-23-2018 09:30 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you start with a rear engine Porsche, vw, or corvair transmission you are good to go.
Some of the others you might need to flip the transmission over. By flipping it, you change the direction of the axle rotation. The issue then becomes a lubrication issue.
Many of the rear engine Porsche and VW transmissions have been installed upside down for mid-engine layouts with the accessories facing the front of the car.
The challenge with most of the setups above is that the engine will then be entirely behind the rear axle.
You could do a reverse rotation of the TH425/TH325 and get the look you want. They are autos, the but 325 could be had in a 4 speed auto. The easiest way to accomplish the reverse rotation is to flip the diff. The second easiest is to convert the TH400 output flange and remote mount a different differential further out to clear the oil pan.
You might hit up engine man to see if he still has his parts from when he was experiementing with this vernsion before going the audi route.
Several threads:
https://www.fiero.nl/forum/A...041015-1-030268.html
https://www.fiero.nl/forum/A...130314-2-104990.html
https://www.fiero.nl/forum/A...100421-2-095676.html
The bracket to flip the differential (need to verify the axle shaft will clear the engine as flipping it raises it as well. Some clear, some don't.)
https://shop.streetdreamsby...-325-4l-transmission
[This message has been edited by fieroguru (edited 11-23-2018).]
shemdogg
Report this Post11-23-2018 04:40 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Guru u da man man! Thank you I got lots of info to read up on!
shem
