Hi,
I have a 88 v6 fiero 5 speed (131000 km) with custom exhaust 2" with muffler without cat.
The muffler is placed instead of the cat and I don't like it.
This muffler bother me when I would work under the car the muffler is too big.
I want to place the muffler in the rear as the stock one.
The car car has :
-custom exhaust with deleted deleted cat and 3.5 resonated tips.
-Exhaust manifold has been ported (for the 6 holes with New gaskets) by me.
-New performance ignition coil and distributor and cap
-New 6 SPARK plug ngk iridium 9 with New 8 mm cables
-New kn air filter with kn oil and gas filter
-New castrol long life titanium edge engine oil 5w30
-New transmission 5w30 oil
-repaired exhaust leak and exhaust manifold leak
-proceed to clean the injectors with injector additive cleaner (ecotec 1101 and bardhal brand in Europe), I have an 6 accel New injector, I think maybe to change the 6 injectors i Will see after the second injector cleaner.
-New preventively changed sensors as oxygen temp filter, map, coolant temp ecm, soon New o2 sensor exhaust
-egr Block off exhaust and intake manifold
-New clutch kit and New clutch Master cylinder
-New brake Master cylinder.
-And some other works like New oil pan...
My question is I must stay with 2" pipe for New exhaust 304l stainless steel or may i use 2.25 or 2.5 with a New sport muffler (maybe akrapovic).. I don't need a cat because before 1993 in my country that's not mandotory to have it.
Thanks.
[This message has been edited by zobari (edited 11-12-2018).]
