   88 15in Tires
88 15in Tires by fgt1988
Started on: 11-02-2018 02:47 PM
Replies: 15 (574 views)
Last post by: fgt1988 on 11-16-2018 11:49 AM
fgt1988
Report this Post11-02-2018 02:47 PM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone know what's the good upgrade size for 15 In front / rear tires that can be mounted on an 88 stock suspension without looking like a 4 wheel truck- lol
I know the 15's in are getting hard to find but I do love my stock wheels especially after they ve been powder coated - If not does a 17x7 front 38mm offset stick out on stock suspension? Just in case I may have an aftermarket wheel in mind -- Thx all . .
Kevin87FieroGT
Report this Post11-02-2018 03:14 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
15” not really hard to find, including 205-60/15 and 215-60/15 sizes.
Tirerack.com
Discounttire.com
Tirebuyer.com
[This message has been edited by Kevin87FieroGT (edited 11-02-2018).]
Report this Post11-02-2018 03:46 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Going up 1 size to 215 front and 225 rear fills the fenderwells nicely. Since the 88 front wheels were narrower than prior years, the 7 inch wide wheel might stand out a bit even with the 38mm offset.
fgt1988
Report this Post11-02-2018 04:30 PM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
that s what I kind had in mind 215/ front and 225 rear -- I wonder if going 50 instead of 60 would enhance the appearance a little -
Report this Post11-02-2018 05:47 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
I would think that 50 series would open the wheel wells more. Especially on the stock rims. Wider profile tires on the narrower front rims will cause the sidewalls to bulge and depending upon the width, may not provide a good bead seal.
Kevin87FieroGT
Report this Post11-03-2018 02:04 PM Click Here to See the Profile for Kevin87FieroGTSend a Private Message to Kevin87FieroGTEdit/Delete MessageReply w/QuoteDirect Link to This Post
Calculator to check various tire dimentions.
https://www.miata.net/garage/tirecalc.html
[This message has been edited by Kevin87FieroGT (edited 11-03-2018).]
fgt1988
Report this Post11-03-2018 03:31 PM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/60-15 5.1in 12.6in 25.2in 79.0in 802 0.0%
225/60-15 5.3in 12.8in 25.6in 80.5in 787 1.9%
205/60-15 4.8in 12.3in 24.7in 77.6in 817 0.0%
215/60-15 5.1in 12.6in 25.2in 79.0in 802 1.9%
I made up my mind to stick with 60's and not to say the 50's are limited on the 15's --- I like this calculator -
Also I found this great site where you punch in your vehicle and it will match you with the appropriate range sizes you can use ---
https://tiresize.com/tires/Pontiac/Fiero/1988/GT/
When I get it all done, I ll post a PIC ... Thanks Everyone
Report this Post11-03-2018 05:48 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
When changing tires to a different size always check out the total diameter so that you don't lose the speedometer calibration. With later OBDII cars that interface with the PCM; they can be edited for different tire sizes. Fiero ECMS do not have a tire size setting. The speedometer is powered directly by the tans speed sensor.
hnthomps
Total ratings: 50
Report this Post11-04-2018 06:25 PM Click Here to See the Profile for hnthompsSend a Private Message to hnthompsEdit/Delete MessageReply w/QuoteDirect Link to This Post
Let me know if you ever see any 245 x 50 x 15 tires because I want/need some. Even the 265 x 50 x 15 tires are very difficult to find now.
Nelson
Report this Post11-04-2018 09:01 PM Click Here to See the Profile for fierofoolClick Here to visit fierofool's HomePageSend a Private Message to fierofoolEdit/Delete MessageReply w/QuoteDirect Link to This Post
Tire Rack has a Hoosier in that size but it's for race track and autocross, only.
cvxjet
Report this Post11-04-2018 11:39 PM Click Here to See the Profile for cvxjetSend a Private Message to cvxjetEdit/Delete MessageReply w/QuoteDirect Link to This Post
I went to 16 x 7 wheels- Voxx Monzas which are a better looking version of the GT "Lace" style wheels....Sadly, Voxx does not make it anymore. 38 mm offset...with 205/55-16 and 225/55-16 they look very good and fill the wheel wells perfectly- still have enough sidewall so your tires aren't stripped off the rim by running over a large ant. (My Fiero is a 85 SE with an 88 rear subframe/suspension) I picked these two sizes because there were a number of popular cars produced using these sizes so most companies produce these sizes in multiple performance versions...Including All-season high performance- My next set will be General G-Max AS-05s which are very light- Previously I have owned the predecessor, the AS-03s which were very good.
I have a getrag Fiero 5 spd and the speedo, with the slightly larger diameter tires, is exactly accurate.....
ASA AR1s have a similar look and the same offset....Tire rack does not show them in 16 x 7 for the Fiero but I went to the company website and it shows them in 16 x 7 with 5 on 100 lug pattern and 38 mm offset. Call the Tire rack and ask them, then if no luck call the company direct.
(I am not smart enough to post pics here)
anaverin
Report this Post11-10-2018 04:14 AM Click Here to See the Profile for anaverinSend a Private Message to anaverinEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am using DRAG DR44 s to reproduce the stock look. They are 45mm offset i believe 17x7.5 . they stick out 11mm farther in the front and tuck in 8mm in the rear. I put 215 45 17 in front and they tuck along with the fenderline and look great. I use a 5mm hubcentric spacer in the rear and run 235 45 17s in the rear. That puts them 3mm from stock, which looks great with a fat tire. the diameters are within 2% of stock. Took alot of work to get to this config. https://www.amazon.com/Drag...x114-3/dp/B01ASAM7ZC
fgt1988
Report this Post11-11-2018 10:00 AM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Well I ended up picking up some new Cooper Ultra 215/60R/15 and 225/60R/15 and once i get them mounted and all- I ll see if i can post PICs,
Dragonfish
Report this Post11-14-2018 11:13 AM Click Here to See the Profile for DragonfishSend a Private Message to DragonfishEdit/Delete MessageReply w/QuoteDirect Link to This Post
Please do! I'm in the market for some tires and I'd like to see how this size looks.
fgt1988
Report this Post11-14-2018 06:42 PM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
sure getting them done on Fri and hopefully i can get it here by weekend
fgt1988
Report this Post11-16-2018 11:49 AM Click Here to See the Profile for fgt1988Send a Private Message to fgt1988Edit/Delete MessageReply w/QuoteDirect Link to This Post
Slight delay as my Fr**** passenger rear strut bumper stop cracked and it was not even 2 yr old - Now I have to remove the strut assembly and reinstall a new KYB kit -
Never ends one thing after another but it keeps me away from trouble.. LOL
