Yup, Wrong timing will often fail emissions but bad/missing Catalyst, EGR, etc, can fail too.
You need right base timing the ECM does the rest.
There is no specs for ECM/PCM timing in data stream to a scanner.
MIL light can/will flash when AB is jumped. Flashing is part of O2 sensor charts in FSM so you "see" the O2 sensor works.
If you have factory cat... "Pebble bed" cat used in 4cyl Fiero can wear out and doesn't work at idle or at all.
Antique tags...
While on
https://www.dmv.com/ut/utah...vehicle-registration , can be hard/impossible to find on
https://dmv.utah.gov/ ...
Most Historic/Vintage/Antique tags severely limits Driving
because the tags have no inspection or emission testing.Is often buried in state codes/rules that have to dig thru other state's web sections/sites.
From
https://www.dmv.com/ut/utah...vehicle-registration | quote | Utah antique vehicle registration plates are for vehicles dating from 1973 or before, while vintage registration plates are necessary for vehicles that are at least 30 years old and used as a collector’s item, or for participating in parades, exhibitions, tours, club activities or occasional, but not daily transportation. An antique car registration may be also needed for special interest vehicles that are at least 20 years old. The vehicles of special interest are classified as such because they are experimental vehicles, have a make that is no longer manufactured or is limited, are used for educational purposes, or are collected, restored, maintained by a hobbyist. |
Meaning If you get stopped driving out of state, to local stores or work then you can lose the tag and worse for driving outside of antique/vintage rules.
Many places still require you to have all emission equipment for the year of car even when you have vintage et al tags. Everything after 1975 needs a cat and whatever else came with from the factory.
