Before buying a new flywheel, I would see if the old one could be turned. Depending on how deep damage is, you should be able to get to hearty, undamaged metal with only a very reasonable amount of out of pocket expense. First though, I would want to see if the heat spots were damage, or just discoloration. It is pretty normal for a flywheel to have heat spots anyway. Clutch to flywheel use creates them even in normal everyday use. If there is warping however....
[This message has been edited by bjm362 (edited 10-18-2018).]
