  Hot or Not??
Hot or Not?? by dma46072
Started on: 10-17-2018 06:33 PM
Replies: 3 (157 views)
Last post by: Gall757 on 10-17-2018 10:21 PM
dma46072
Report this Post10-17-2018 06:33 PM Click Here to See the Profile for dma46072Click Here to visit dma46072's HomePageSend a Private Message to dma46072Edit/Delete MessageReply w/QuoteDirect Link to This Post
Does anyone know of the ohm reading I should get when checking my temp guage sender? I grounded each of the sender wires to the battery to verify that the guage and light functioned......Good news they did. Also when I turn the key the guage will move to the far right until I let of the key. When the car is running the guage stays at the far left. My question is would a bad guage sender be the cause of the situation described above?
Thank you in advaance for your help.
Spoon
Total ratings: 61
Report this Post10-17-2018 08:53 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Year? Make? Engine?
Give us a little something to go on. I'm assuming its a Fiero but other info can help provide a proper answer.
Spoon
dma46072
Report this Post10-17-2018 09:58 PM Click Here to See the Profile for dma46072Click Here to visit dma46072's HomePageSend a Private Message to dma46072Edit/Delete MessageReply w/QuoteDirect Link to This Post
I do apologize it is a 1986 SE 2.8.
Report this Post10-17-2018 10:21 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Most likely the gauge sender needs replacement.
Note an additional problem with that circuit that was a factory error.
http://www.fierosails.com/tempgage.html
