The previous owner of my 86 GT hates me. At some point, they hotwired past the dimmer transistor (.8 GRN/WHT => .8BRN behind the dimmer switch), and did SOMETHING to disable the courtesy chime. I've had a couple dead batteries from leaving the parking lights on over the years, and I want to get the car toward factory new function, so I decided to try to fix all this. The first one was easy (I thought). I deleted the hotwire and repaired the GRN/WHT wire to its original run. Everything worked! The dimmer could go from nice and bright gauges to all the way dark. I mostly drive during the day with lights on only for rain, so I left them nice and bright for now. About a week later, I'm taking off at night, and as I back out of my parking space, all the interior lights blink out. By the end of my long driveway, they pop on one more time and blink out for good. Loose wire, I thought, must have bumped something or tugged too hard to make my splice under the dash.
Later this week, I see the temp gauge has given up. Car off, needle in rest position on the left, car on, needle at exactly 100° and stays there.
Today, I open it up and start testing things.
TEMP GAUGE:
Service Manual pp. 8A-80-0
-I corrected the bulb test wire years back to prevent gauge or needle damage, needle does not jump on TEST
http://www.fierosails.com/tempgage.html-Followed thread:
https://www.fiero.nl/forum/A...110502-2-105462.html-Sensor terminals are a little crusty, but the connectors aren't cracked.
-After scratching a bit, ohmmeter read normal range for just having been driven.
-Shorting connector wires to ground does NOT peg needle to right, but does turn on temp warning light.
-Turn signal makes tach needle dance by about 1000 RPM at idle with A/C on, even after ground G201 cleaned (see below)
Conclusion: Wiring problem! Where? There was a delay of weeks since I'd touched anything til the gauge started acting up.
LIGHTS:
Service Manual pp. 8A-114-0
https://www.fiero.nl/forum/Forum2/HTML/140099.htmlhttps://www.fiero.nl/forum/A...050119-2-054366.html-All exterior lights function properly
-No fuses blown, no bulbs burned
-Continuity on BRN, GRN, DK GRN/WHT
-12V in and out of transistor at no dimming (car off, park lights on)
-Continuity on GRY from Gauge light fuse (back of block) to dash plug
-Cleaned ground G201 (ring connector broke at a touch, replaced with new ring connector)
CHIME:
Service Manual pp. 8A-77-0
-Stared at the wiring diagrams
-Looked for any missing or spliced wires
-No idea where to start.
