  Rarararararaarara - noise coming from left rear
Rarararararaarara - noise coming from left rear by longjonsilver
Started on: 10-06-2018 03:10 PM
Replies: 25 (407 views)
Last post by: solotwo on 10-16-2018 07:58 PM
longjonsilver
Report this Post10-06-2018 03:10 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Recently my84 started making rararararara kinda hum like noises coming from the left rear (or so i think).i have checked the fluid level in the trans and engine (both good) and the adjustment of the parking brake - the lever hits the stop on the caliper when brake disengaged. Where do i go next to figure this out? i don't wanna drive and be left stranded or make a small problem into a big one.
jon
I'm the original owner of a white ' 84 2M4 purchased Dec 10, 1983 from Pontiac. Always garaged, no rust, 4-wheel drifts are fun!
David Hambleton
Report this Post10-06-2018 04:43 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Might be a wheel bearing. Does the hum change with the car speed?
How are the brake pads & rotors? Rust buildup on rotors can rub on pads.
[This message has been edited by David Hambleton (edited 10-06-2018).]
Report this Post10-06-2018 05:12 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
Hit any potholes lately? A broken cord in a tire will rararaa sometimes.
longjonsilver
Report this Post10-06-2018 07:33 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i thot about a wheel bearing. The rararararararara does change with speed, getting worse on the freeway. It begins at say 40mph. Can i just grease it? Other wheel bearings that i had that went bad on my old Mazda squeeled not rararararara.
The pads were fine, until i drove with the ebrake on for several miles. They were HOT! The exterior pad is worn more than the interior pad. Hmmmm . The rotors look good.
jon
longjonsilver
Report this Post10-06-2018 07:35 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
longjonsilver
Member since Nov 2001
My rear tires are SHOT! Almost bald. So bad that i won't drive in the rain as the rear gets squirrly. i will be taking her off the road this Oct 31 and getting new tires first thing in the spring. i'll check the tire for visible problems.
jon
wftb
Report this Post10-06-2018 09:04 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Depending on the miles, it could be a wheel bearing. But 80's GM wheel bearings from my experience easily last 300,000 KM or more. I think you hit the nail on the head when you mentioned the tires. It is amazing how a new set of tires quiets a car down.
[This message has been edited by wftb (edited 10-06-2018).]
David Hambleton
Report this Post10-06-2018 10:02 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yep, lol! Only one has been replaced on my three Fieros; the right rear on the '84 SE at 372,300 kilometers.
Worn tires and/or alignment issues can certainly result in humming noises.
I'm not exactly sure what 'rararararara' sounds like... Maybe like big lug off-road tires on pavement?
Bearings are more rrrrrrrrrrrrrrrrr with the pitch depending on speed.
David Hambleton
Report this Post10-06-2018 10:14 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
David Hambleton
Member since Nov 2012
jon
Bald, round tires can still be quiet; cupped tires or mis-aligned tires make noise as the tread hops when it loses contact with the road as the wheel turns.
Put your hand across the tire tread and sweep your hand around the tire. You should be able to feel if the tread is cupped or lumpy versus smooth and round.
Protruding edges of the remaining tread caused by misalignment could make road noise.
liv4God
Report this Post10-07-2018 12:13 AM Click Here to See the Profile for liv4GodSend a Private Message to liv4GodEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you ate crossing around 55 or so and then put the clutch in does the sound stop? Or put it in neutral, any difference? If so, out could be something trans or clutch related. One of mine had a wrong size tob installed that would rararararara as it shook around on the trans spline. But no sounds when putting the clutch in since it would be held in place between the pressure plate and fork.
Daryl M
Report this Post10-07-2018 12:20 AM Click Here to See the Profile for Daryl MSend a Private Message to Daryl MEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm guessing tread separation.
longjonsilver
Report this Post10-07-2018 07:40 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
i'll go down Monday and get new tires. i don't want to miss the last three weeks of driving and i was planning on getting new tires in the spring anyway. If its NOT tires, then i will want to repair it this winter.
thanks guys
jon
[This message has been edited by longjonsilver (edited 10-07-2018).]
da.slyboy
Report this Post10-07-2018 09:40 AM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Also check if your dust shield isn't rubbing your disk. Just have to bend it a little to get it to quit.
longjonsilver
Report this Post10-07-2018 12:01 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
My dust shield has rubbed in the past - i noticed it by the echo bouncing off the buildings and railings by the side of the road. Dust shields make a high pitched squealing sound. This is more of a rararararara or a rrrrrrrrrrrrrrr, and it gets louder as i drive faster. It starts about 25mph and by 60 its loud!
jon
Spoon
Total ratings: 61
Report this Post10-07-2018 10:01 PM Click Here to See the Profile for SpoonSend a Private Message to SpoonEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'm wondering if you swapped the rear tires for the front tires, would the rararararara move to the front as well.
Note,, I'm not suggesting, just wondering.
Spoon
longjonsilver
Report this Post10-08-2018 06:16 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Spoon
i'm running 16s on the rear and 14s on the front. Kinda funny to swap them, but i guess it would allow me to tell if the rararararara comes from the front.
jon
David Hambleton
Report this Post10-08-2018 08:22 AM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
You could try switching the wheels from one side to the other side to see if it makes a difference. The opposite rotation could affect the noise as well.
[This message has been edited by David Hambleton (edited 10-08-2018).]
Total ratings: 328
Report this Post10-08-2018 02:42 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is the sound with vibration or does it just sound like a grinding noise?. Get the tire off the ground, support it by the suspension arm if possible, and block the front wheels. . With the car in neutral turn the wheel by hand and listen for noise. Possibilities could be tire, wheel bearing hub, CV axle, grabbing brakes or even a transmission shaft bearing. .
longjonsilver
Report this Post10-09-2018 06:27 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
This is why i want to nail down befor ewinter if it is the tires or not, because if it is more serious than tires, then i want to do the work this winter when i have it off the road. There doesn't appear to me when i drive it that there is vibration. It is more like a grinding noise. I got the wheel off the ground and the ebrake is not dragging, so i guess the hydraulic brakes are not dragging as well.
Thanks. i'm gonna try that today on my way to the scrapyard to pick up a power booster from a 95 Sonoma for the booster upgrade, as well as some stuff from the three Fieros there that the world seemingly has forgotten. The noise seems to be coming from the left rear, Switching tires should tell me if its tires or the above mentioned more serious things.
thanks guys, i appreciate it
jon
longjonsilver
Report this Post10-09-2018 01:05 PM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
longjonsilver
i switched the rear tires side to side and drove to the scrap yard at some 50mph and no rarararara. Either it was the belt and by rolling the other way it is not slapping, or it is slapping but i don't hear it because its on the other side, but either way, i guess i can conclude that it is the tires and not other more serious stuff. i need new tires anyway.
thanks to all
jon
Total ratings: 458
Report this Post10-09-2018 02:35 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Interesting. I thought it would've been a rear wheel bearing for sure... but in retrospect, when one of my rear wheel bearings was failing years ago, it was making more of a squawking noise.
boostedbird
Report this Post10-09-2018 04:30 PM Click Here to See the Profile for boostedbirdSend a Private Message to boostedbirdEdit/Delete MessageReply w/QuoteDirect Link to This Post
While I have nothing of note to contribute, I did read the whole thread.
Anyone else?
https://youtu.be/SNYJcOTOcLU
David Hambleton
Report this Post10-09-2018 09:33 PM Click Here to See the Profile for David HambletonSend a Private Message to David HambletonEdit/Delete MessageReply w/QuoteDirect Link to This Post
thanks to all
jon
It might be wise to ask your tire installer if he thinks there's any unusual wear that might be alignment related. You might avoid premature wear on the new tires if something needs adjusting.
longjonsilver
Report this Post10-10-2018 07:56 AM Click Here to See the Profile for longjonsilverClick Here to visit longjonsilver's HomePageSend a Private Message to longjonsilverEdit/Delete MessageReply w/QuoteDirect Link to This Post
Anyone else?
Feel free to make fun of me if you wish, but these kind gentlemen (and many others) have helped me, a non-mechanic, keep my car on the road for 15 years now, ever since i joined PFF. They have helped me put in a clutch, put in a throwout bearing, diagnose trouble codes, rebuild my steering rack, rebuild my steering column, rebuild my gen 1 headlight motors, overhaul my entire suspension, install a 3core radiator, install GT gages into my 84, and move my battery into the front. This winter they will help me move my battery under the passenger headlight, recover my drivers seat, install gen 2 headlight motors, and install a larger power booster for my brakes,
Thanks again guys.
jon
boostedbird
Report this Post10-10-2018 12:20 PM Click Here to See the Profile for boostedbirdSend a Private Message to boostedbirdEdit/Delete MessageReply w/QuoteDirect Link to This Post
You completely misinterpreted that video. I was more focused on the noise the guy made, not the obvious part.
Notorio
Report this Post10-14-2018 11:46 AM Click Here to See the Profile for NotorioSend a Private Message to NotorioEdit/Delete MessageReply w/QuoteDirect Link to This Post
I was also betting on the wheel bearing. Before I replaced mine it was exactly the ra-ra-ra you described, with the frequency matching the car speed, not at all a squeal or squawk. It's interesting that the same part failing can produce different sounds! Anyway, congratulations on finding the real cause of the problem. Well done!
solotwo
Total ratings: 62
Report this Post10-16-2018 07:58 PM Click Here to See the Profile for solotwoSend a Private Message to solotwoEdit/Delete MessageReply w/QuoteDirect Link to This Post
My thought was the same. Rear wheel bearing. I had to replace one on the 87.
