  Can I bypass the throttle body return line?
Can I bypass the throttle body return line? by djcottrell
Started on: 09-20-2018 02:33 PM
Replies: 2 (107 views)
Last post by: djcottrell on 09-20-2018 03:01 PM
djcottrell
Report this Post09-20-2018 02:33 PM Click Here to See the Profile for djcottrellSend a Private Message to djcottrellEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am putting in a racing fuel cell in my 84 with the 2.5 TBI. It will be using a holly fuel pump and regulator. It is my understanding that if I am using the holly regulator that I can terminate the return fuel line as I will not be using the factory regulator.
I am putting in a 350 in a year or so and I would hate to run a line and remove it later.
One of my concerns is the quality of the regulator and what it could do to the throttle body if it fails. In this case would it be best to use both in case of failure.
fierosound
Total ratings: 287
Report this Post09-20-2018 02:57 PM Click Here to See the Profile for fierosoundClick Here to visit fierosound's HomePageSend a Private Message to fierosoundEdit/Delete MessageReply w/QuoteDirect Link to This Post
You're going to have to run a new fuel line anyway.
What's the problem in running a return line next to it as well?
djcottrell
Report this Post09-20-2018 03:01 PM Click Here to See the Profile for djcottrellSend a Private Message to djcottrellEdit/Delete MessageReply w/QuoteDirect Link to This Post
The carborated 350 going in does not need a return line. I was hoping to prevent running the line and removing it later.
