Since your car had a severe tire wear issue, the first thing I would do is check check every suspension bolt/nut and verify it is at the proper torque. Look around at the bolt heads to see if there are signs of a bolt sliding or being moved from where it once was. It isn't uncommon for people to add larger brakes or more power and be able to slide a snug but not properly torqued bolted connections of the suspension due to the increased load, which will throw off the alignment. If it shifted in that direction, tighten the bolts there (this is where they want to be with your driving style and are less likely to shift again).
Then have the alignment checked for the current setting. This should show you which corner of the car has the issue, what type it is (Caster, Camber, Toe), then you can start working to find the culprit (or confirm what you found in your earlier inspection).
Once you go poly bushings (and/or rod end lateral links in the rear), then bushing deflection becomes less, so you can run closer to zero toe in the front and rear.
For my 88, I do all my own alignments using the string method with the car sitting on blocks.
I target to the tow to be 1/32" to zero toe in. camber front/rear is 0.7 degrees negative (top of tire tucked in, bottom kicked out), and front caster set to the maximum I can get on both sides, with both sides set within 0.1 degrees. Normally this is about 6-7 degrees. Using this setup I have over 46K miles on a wide set of extreme summer tires with a 200 wear rating and the engine has 382 whp, so I can spin the rears w/o issue, but normally just get them grip.
[This message has been edited by fieroguru (edited 09-21-2018).]
