  4.9 Pilot Bearing
4.9 Pilot Bearing by P.O.L. Mafia
Started on: 08-21-2018 06:57 AM
Replies: 7 (261 views)
Last post by: fieroguru on 08-21-2018 06:51 PM
P.O.L. Mafia
Report this Post08-21-2018 06:57 AM Click Here to See the Profile for P.O.L. MafiaClick Here to visit P.O.L. Mafia's HomePageSend a Private Message to P.O.L. MafiaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I am slowly collecting the parts to drop a 4.9 in my Fiero. 86 GT 2.8 4 speed. I've got just about everything but it hit me last night that I don't have a pilot bearing for the input shaft of the 4 speed. Is there a special one? do I have to fabricate this? any insight would be awesome.
Mike T
CCWorks
http://www.ccworks.org
Choppers and Fiero's RUUUULLLLEEEEE
michael.tullock@ccworks.net
Total ratings: 260
Report this Post08-21-2018 11:10 AM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
No pilot bearing is used with any Fiero manual transmission.
P.O.L. Mafia
Report this Post08-21-2018 11:59 AM Click Here to See the Profile for P.O.L. MafiaClick Here to visit P.O.L. Mafia's HomePageSend a Private Message to P.O.L. MafiaEdit/Delete MessageReply w/QuoteDirect Link to This Post
https://www.rockauto.com/en...h+pilot+bearing,1964
Not to disagree but I've never seen a manual trans without one. If you don't you will have clutch chatter when engaging.
Mike T
CCWorks
pmbrunelle
Total ratings: 63
Report this Post08-21-2018 12:25 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
I guess you haven't looked at a Fiero transmission yet.
[This message has been edited by pmbrunelle (edited 08-21-2018).]
P.O.L. Mafia
Report this Post08-21-2018 12:38 PM Click Here to See the Profile for P.O.L. MafiaClick Here to visit P.O.L. Mafia's HomePageSend a Private Message to P.O.L. MafiaEdit/Delete MessageReply w/QuoteDirect Link to This Post
well you are correct, I've never cracked a Fiero, but I have done a bunch of others. guess I'll see when I drop the motor later.
Mike T
CCWorks
pmbrunelle
Total ratings: 63
Report this Post08-21-2018 12:55 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
If you open the Fiero transmission, you'll find its input shaft is already supported by a pair of tapered roller bearings. Adding a 3rd support would be ill-advised.
P.O.L. Mafia
Report this Post08-21-2018 01:12 PM Click Here to See the Profile for P.O.L. MafiaClick Here to visit P.O.L. Mafia's HomePageSend a Private Message to P.O.L. MafiaEdit/Delete MessageReply w/QuoteDirect Link to This Post
interesting, thank you for the info, I need to look into this.
Total ratings: 260
Report this Post08-21-2018 06:51 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Don't worry, Rock Auto's catalog is wrong (again).
This is correct.
The other piece I would add is that due to the lack of protrusion of the GM FWD crankshafts (they are essentially flush with the bell housing face) and the lengths of the transverse manual transmission input shaft, there isn't sufficient length for them to even touch, let alone slide into each other to be supported. There is one know exception with the a case swapped F23 and 3800, that input shaft is actually long enough to slide into the crankshaft by about 1/8", but the OD of the end of the shaft is too large to fit in the ID of the 3800 crankshaft, so you use a flapper disk to grind a small portion away so nothing touches.
