  Anyone using FieroAddiction 4.9 88 front mounting bracket?
Anyone using FieroAddiction 4.9 88 front mounting bracket? by Raydar
Started on: 07-21-2018 02:35 PM
Replies: 11 (246 views)
Last post by: Dennis LaGrua on 07-22-2018 10:32 PM
Total ratings: 461
Report this Post07-21-2018 02:35 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Is anyone using this bracket on the 4.9, swapped into an 88?
Does anyone know what bottom mount is needed, to work with this bracket?
Obviously, I can take everything apart and measure / eyeball. But it would be nice to know before I get hip-deep into my project.
Already did a search. Found nothing meaningful.
Thanks!
Spadesluck
Report this Post07-21-2018 03:37 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have a Fiero that has an Archie 4.9 swap sitting in my driveway, did he use his own parts or source them out? I ask cause may i can take a picture of what I have in use compered to what you got?
Total ratings: 461
Report this Post07-21-2018 05:06 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
I don't think Archie ever did a 4.9 installation. Most everything he did was a SBC.
With that said, if it's really a 4.9 - whoever installed it - I certainly wouldn't mind seeing how it's mounted. Interested in the bracket under the oil pan, and the rubber mount that it's bolted to. But please don't go to a bunch of trouble.
Total ratings: 260
Report this Post07-21-2018 07:29 PM Click Here to See the Profile for fieroguruSend a Private Message to fieroguruEdit/Delete MessageReply w/QuoteDirect Link to This Post
Total ratings: 461
Report this Post07-21-2018 10:51 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Here you go Steve:
Perfect. Thank you very much.
[This message has been edited by Raydar (edited 07-21-2018).]
Spadesluck
Report this Post07-22-2018 01:53 AM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
My bad, i was over zealous in my post. I meant to say Fiero Factory...jesh
Total ratings: 461
Report this Post07-22-2018 12:25 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Ah. Cool. That's who did my initial install. Yours is probably just like mine.
I'm having to re-engineer mine, just a bit. Thinking about swapping Jon's bracket in, instead of the FF one.
Thanks, though. Much appreciated.
Spadesluck
Report this Post07-22-2018 01:54 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Whats the reason to changing brackets? The 88 cradle that different on the mounting?
Total ratings: 461
Report this Post07-22-2018 04:04 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Long story.
The short story is that it appears to not be sitting level.
I want to raise the "pulley end" of the engine, just a bit. I also don't like how close the pan sits, to the FF mounting bracket, and studs.
Been that way forever, but I'm doing some other stuff too, so I might as well do this, while I'm at it.
Total ratings: 207
Report this Post07-22-2018 04:14 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I remounted my 4.9 for the same reason, but I eliminated the mount below the crankshaft.
I have four mounts to the cradle, down low and no dogbone.
Total ratings: 461
Report this Post07-22-2018 10:00 PM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
The front mount, behind the compressor, is likely no longer a viable option. At least not with the Deville bracket.
I have an Allante bracket on the way, Mounts a little differently from the Deville bracket. We shall see.
Total ratings: 328
Report this Post07-22-2018 10:32 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
Used WCF front mount and a universal Energy Suspension poly mount. Its 4 point like Joes with no dog bone. .Trans mounts are Fiero auto. Brackets are just standard Caddy stripped of the rubber.
