  Stuck in 4th
Stuck in 4th by Boltshot
Started on: 07-16-2018 06:29 PM
Replies: 7 (165 views)
Last post by: pmbrunelle on 07-17-2018 08:32 PM
Boltshot
Report this Post07-16-2018 06:29 PM Click Here to See the Profile for BoltshotSend a Private Message to BoltshotEdit/Delete MessageReply w/QuoteDirect Link to This Post
All visible cables and linkages appear to be intact, shifter moves said cables and linkages when used. Nearly zero resistance when moving shifter around, clutch works fine and completely stuck in 4th. Must be internal to the trans, any thoughts on what could be broken?
pmbrunelle
Total ratings: 62
Report this Post07-16-2018 08:02 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Isuzu, Muncie, or Getrag?
mousemeat
Report this Post07-16-2018 11:45 PM Click Here to See the Profile for mousemeatSend a Private Message to mousemeatEdit/Delete MessageReply w/QuoteDirect Link to This Post
once you figure out what trans you have...you might want to check out shifter rebuild lit, etc...replace worned bushings, etc..I had an similar problem with my 5 speed, and would get caught in gear , from time to time..I ordered kits from Rodney, and installed the replacement items...My troubles ended...
Total ratings: 205
Report this Post07-17-2018 01:19 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
I suspect that one of the shift rails internal to the transmission has become detacted.
I've had it happen to me; all of a sudden, it doesn't shift anymore and the shifter, cables and levers move just fine.
Boltshot
Report this Post07-17-2018 04:56 PM Click Here to See the Profile for BoltshotSend a Private Message to BoltshotEdit/Delete MessageReply w/QuoteDirect Link to This Post
My trans is a 4 speed manual from a 3.8L SE from 1986. Not sure what make the tranny is or how to identify it.
Not too keen on the idea of pulling the trans and having it rebuilt. Was hoping it could be easily fixed and not sent to a specialist if I did have to pull it.
Report this Post07-17-2018 05:13 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
So it's the Muncie, or also called the M17. You should be able to find another one for a reasonable price.
[This message has been edited by Gall757 (edited 07-17-2018).]
Total ratings: 205
Report this Post07-17-2018 06:18 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Same trans as my problem occurred with. Also in an 86 SE...
pmbrunelle
Total ratings: 62
Report this Post07-17-2018 08:32 PM Click Here to See the Profile for pmbrunelleSend a Private Message to pmbrunelleEdit/Delete MessageReply w/QuoteDirect Link to This Post
The Muncie shifter is rather simple. I think it is within the realm of a Saturday mechanic to open the trans and debug a shifter issue.
Once the bad parts are identified, they can be replaced with parts from a donor transmission, if applicable.
If after removing the shift fork the synchro is still stuck in gear, then dealing with that is a step up in difficulty; time for a pro.
[This message has been edited by pmbrunelle (edited 07-17-2018).]
