| quote | Originally posted by RPYRAZOO: Can an '87 V-6 be driven at a constant 220* ? My radiator fan is wired to run all the time and at highway speed the fan impedes air flow. No time for a new fan motor just now. When I do replace the motor that has a clutch, which should I buy? |
220-230°F is fine for most engines not just Fiero engines. Over 235-240°F is hot but not "bad/dangerous" if not done every day.
Engine is "safe" Running near Coolant Boiling Point, ~265°F w/ 50/50 mix and 15PSI cap, but in this condition can Boil Over after shutdown because have little or no overhead to allow coolant heat soaking in the engine w/o WP running. For many engines, Piston Rings, Fuel Map, etc, are not happy running the engine that hot either.
Double check dash gauge w/ ECT sensor from ECM scan tool. Should be close but often not exact even when coolant system is perfect because mounting location etc. Even small difference in how mounted and wiring problems can make dash gauges to lie. OP and Fuel can have same wiring problems and Why many tell people to use a "shop" gauge to test OP when dash says high or low pressure.
OE and most Aftermarket fans can hate being on all the time. Example: Bearings and/or Brushes wear out when on full time. Worse, Many OE Fan/Blower motors have simple "Brass" bearings and can fail fast like many PC w/ cheap fans. Bearing can fail making a lot of noise or locked up and fry it and other things like relays/switches.
