  LAST YEAR ?
LAST YEAR ? by Lou6t4gto
Started on: 07-13-2018 09:18 PM
Replies: 5 (238 views)
Last post by: Reallybig on 07-15-2018 01:36 PM
Lou6t4gto
Report this Post07-13-2018 09:18 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
What was the Last Year for the 3800 ? Best year and.. WHY? Thanks
Report this Post07-13-2018 09:50 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
https://en.wikipedia.org/wiki/Buick_V6_engine
Most Fiero owners used the Series 2 engines, which ended in 2005.
[This message has been edited by Gall757 (edited 07-13-2018).]
Total ratings: 328
Report this Post07-13-2018 10:35 PM Click Here to See the Profile for Dennis LaGruaSend a Private Message to Dennis LaGruaEdit/Delete MessageReply w/QuoteDirect Link to This Post
The 3800 engines last year was 2008 but the Supercharged version ended a year earlier. Like all engines I believe that GM decided that all iron engines had run their course. In came N/A V6 high value engines that had similar power as the supercharged 3800 and could be built for lower cost. Next came the next generation all aluminum VVT DOHC high feature engines that are used today.. Depending on the series those engines equal or greatly exceed the power of the 3800. Finally there is the ecotec 4.3L V6 used in GM trucks. The 3800 is no doubt a great high reliability engine, many like it, but it is considered low tech by today's standards.Until the high feature engines become easier to swap it may remain a Fiero favorite.
Reallybig
Report this Post07-15-2018 12:55 PM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
Early high feature engines had problems that gm walked away from by telling customers they needed a new engine after 120k miles.
9 thousand dollars for a new engine installed in your well equipped reasonably new SUV, or it's a parts car. To me GM'S new engines should be feared
[This message has been edited by Reallybig (edited 07-15-2018).]
Lou6t4gto
Report this Post07-15-2018 01:17 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
sounds like GM went Backwards 3 DECADES ! from an engine that runs well to 300k to one that is done at 120k, almost as good as the "Constant Velocity Transmissions" ! ( nissan and ford), Absolute garbage)
Reallybig
Report this Post07-15-2018 01:36 PM Click Here to See the Profile for ReallybigSend a Private Message to ReallybigEdit/Delete MessageReply w/QuoteDirect Link to This Post
One of the problems is the vvt which stretches the long timing chain as previously normal deposites build in the engine. GM actually extended the warranty to 120k from the typical 60k so that they could walk away from their crap at what could be considered a reasonable engine life expectancy. They just kept replacing the timing chains under the extended warranty because there is no fix for poor design.
At least that's what I've read online after dealing with this problem personally and researching the issue
