Sounds like a low refrigerant level . If its still an R-12 system then the low and high side pressures will be significantly different then if it was an R-134a retrofit. Check with a gauge set. If you low on refrigerant then first find the leak, fix it and do the R-134a update . Common leak areas are the compressor seals and at the O ring fittings. You will need to add leak detector and have an UV light to trace leaks. Repairing the A/C system is much more involved than this so read the service manual and follow the proper procedures..
