So, the CS130 shouldn't *need* an idiot light to start charging - it should eventually self-energize... running the engine up to 1500 or 2000rpm should be enough to get it going. If it doesn't, there is probably something wrong with the alternator. I am not familiar with the '88's wiring, but in general:
There are four terminals on the back (and they will be labeled), PLFS plus the big B+ battery terminal. I actually don't know how the '88s are wired, but the idea is that "S" is how the alternator controls its charging, so it either gets connected directly to the B+ terminal (how us DIY retrofit hacks do it) or it will be connected further upstream to the car's wiring harness (how the factory does it, for better charge management). At that point, with a couple thousand revs on the motor, it should start charging by itself. So, you can test for battery voltage at both S and B+ with the car off to be sure those pieces are in place.
The idiot light is there for us and so that the alternator starts charging immediately. It's connected to terminal L on the alternator. With the engine stopped, you should have a ground on that terminal. With the engine running, you should get alternator voltage
once the alternator starts charging. You can quick & dirty simulate the lamp by getting a 35-500w 5w (or greater) resistor and bridging L directly to the battery terminal. It'll kill your battery if you leave it this way, but for testing purposes it's an easy way to rule out the idiot light wiring.
I think on the Fiero P is not used, but the I terminal I believe will be connected, and connected to a switched ignition source. You should get 12v here with the car on, but the engine off.
That's all the testing you can really do... test those three terminals. If they all check out, it's the alternator.
