| quote | Originally posted by Jay-ID:
I've tried an axle puller and two pry bars with no luck. What worked for me was a big end wrench (28mm+ or 1 1/4"). The two "teeth" of the wrench fit around the axle between the transmission and the tri-pot, allowing you to apply even pressure to both sides. It can scar your tri-pot a bit. Good luck! |
I have used this method as well when a pry bar doesn't work. A gigantic wrench or fork and a quick rap from a hammer works really well if you have the space. I used a damaged pickle fork - clamped it into a vise, heated it up real good, and then hammered a jack roller into the mouth to widen the tines.
[This message has been edited by thesameguy (edited 07-18-2018).]
