Was wanting some feed back on my KR problem. 3.4 with 7730 and DIS. Lots of other add-ons. Trying to get it tuned but need to resolve this. First off there is no KR under load. In neutral or with clutch in I get KR if I snap the throttle quickly. I can rev the engine up to the same rpms and get no KR if I do it slowly. To me it seems something isn't responding quick enough to the quick rev whether it be the ecm, iac, valve float. I don't know. I have looked over everything externally really well for exhaust or other things hitting on something else. Any info helps thank you.
Momentary KR's should not be a problem. Steady KR's over an extended RPM range during hard acceleration can be. If there are no KR's under load then I would not worry about it.
Originally posted by fierofinder: Was wanting some feed back on my KR problem. 3.4 with 7730 and DIS. Lots of other add-ons. Trying to get it tuned but need to resolve this. First off there is no KR under load. In neutral or with clutch in I get KR if I snap the throttle quickly. I can rev the engine up to the same rpms and get no KR if I do it slowly. To me it seems something isn't responding quick enough to the quick rev whether it be the ecm, iac, valve float. I don't know. I have looked over everything externally really well for exhaust or other things hitting on something else. Any info helps thank you.
Did you block off the EGR? If not, did you NOT upgrade your injectors? Sounds like you might be running a bit lean at tip-in...
EGR is blocked off. Injectors are 17#. If it's leaning out I'm thinking that the tune could fix that or possibly I need to invest in an adjustable fuel pressure regulator. The other thing is I'm not hearing any knock. Just showing up on the scan
Originally posted by fierofinder: EGR is blocked off. Injectors are 17#. If it's leaning out I'm thinking that the tune could fix that or possibly I need to invest in an adjustable fuel pressure regulator. The other thing is I'm not hearing any knock. Just showing up on the scan
Yes, my 3.4 does that as well and I'm using the 17# Camaro injectors. I have yet to edit out EGR in the ECM (stock). You need to do the same for the 7730. A motor can run fine without EGR once you disable it in the programming.
I'll check that out. Sure be nice if it is something that easy to fix. Thank You.
My 7730 program (on my other 3.4) has it edited out and run much better on tip-in...but I also have KR edited out as well... Ryan @ SinisterPerformance did that editing...
Ryan mentioned to me that he could do that but we were trying to figure out what was causing the knock to be safe. I'll have him do the same for me so I can move on with getting it tuned.
Let me save you months of internet guess work... Newsfash: it's the lack of EGR. Just have him do it. Also, if you switched to DIS, you need to increase the gap on your plugs to .060 unless you increase your compression ratio with DOHC pistons then you want it around 0.055 or slightly less.
[This message has been edited by lou_dias (edited 06-21-2018).]
Not sure an adjustable fuel pressure regulator alone will solve the lean issue. The O2 sensor will still be sending a signal to the ECM based upon what it reads in the exhaust. If you raise the fuel pressure you just might see the ECM decrease the pulse width to the injectors leaving you back where you started. BTW, knock at higher speeds is not always easy to hear. The scanner tells the story.
Still waiting to hear back from Ryan. Haven't been in contact with him since October when the rain started. When he has time I'll have him do I new tune and disable the EGR. While I wait I'll check that spark gap, thats new info to me. Once I get that new tune I'll let you all know how it turned out. Thank You.
Still no word from Ryan. I did find out how to delete EGR and I found that it had already been done. I have changed the spark gap as well. Ryan had mentioned advancing knock recovery rate so that timing advance would return to normal faster, going to look into that. planning on starting a post on gearheads as well so I can learn to navigate the tuner pro better.
