I'm thinking of rebuilding my 2.5 engine and want to order a rebuild kit but they all require main bearing, piston and rod bearing sizes. How do I tell which ones I need?
Anyway my car is an '85 but just to be sure how can I verify exactly what engine do I have?
until you "Open it up" there's no telling if the cylinders will remain standard, if the Crankshaft Needs to be turned .010/.010. you don't even know for sure if someone else has previously "done it".
Thanks for the replies. So I'll have to open up the engine soon and I'm wondering - are there any rebuild kits available anymore? The only company that made these I think was Enginetech but they are all out of stock. Do you guys know where can I get a rebuild kit?
These guys have already covered it but I figured I would share my dumb move when I rebuilt my 2.8l. I like you wanted to get a head start and just bought standard rings/bearings but when I took the motor apart it had already been rebuilt at some point. Lesson of the story open it up and then figure out what you need. Less chance to waste money.
You will need to buy or borrow a micrometer to measure the crankshaft journals and an inside micrometer to measure the cylinder bores. Compare these to the specs in the service manual. Sometimes everything measures up and a simple hone of the cylinders, a new set of standard size bearings, rings, seals and cam bearings can be used but not always. Be sure to measure the cylinders for taper, out of round and inspect the crankshaft for scores on the journals. The process is more involved than this but it should give you an idea.
[This message has been edited by Dennis LaGrua (edited 12-01-2018).]
If you are going to rebuild it, (Being a 1985 engine) make sure it has a roller cam. (1985 was a split year)( you Can install the stock roller cam into the flat tappet block) use a metal gear drive instead of "fiber"
Thanks, I will look into that. I'm not even sure the engine is an 1985. It has the pre 87 TBI for sure though.
Anyway back to my latest question - where can I get a rebuild kit? It seems there are only some left on eBay but I'm not sure eBay is a legit place to buy these things.
you MAY be" better" off buying your Parts Separately. that way you can get the BEST. Clevite or King Bearings, perfect circle rings, "coated" pistons. Do not buy Cut Rate cheap Gaskets !
That sounds reasonable. How would I go about that? I've only seen "full" kits and not parts sold separately. Are they even available to find under "fiero" and "parts"? Or should I just measure all around buy non-specific Fiero parts?
Thanks.
No one has asked the most pertinent question.
WHY?
What makes you think it needs a rebuild? You haven't posted any compression/vacuum/leakdown/oil pressure results.
I have been accused before of coming across like God when discussing building engines. That's because I've built more than a few, and seen well meaning people tear down a perfectly well running engine 'that needs rebuilt' when it doesn't. Half the time they end up wrecking the thing.
That's true, I haven't done any of these tests. There are just some symptoms that I only assume are mechanical wear. It may also be some negligence in maintenance but it's so tough to troubleshoot since so much stuff was done. And I still drive it everyday.
All I know is from observations - that it consumes oil, spits it out to the air filter area, starts poorly when cold, blows a lot of white/blue smoke when cold and when restarted hot for a few seconds. Has a rough and uneven idle when hot. Also it loses coolant with no visibile spill other than the reservoir will blow out sometimes some coolant when it's full. Oil looks "clean" as in no coolant contamination but it has a LOT of carbon buildup when I remove the valve cover. Mileage is I'd say pretty average for an automatic - I get around 28 MPG highway (65-85 MPH) currently when it's wintertime and we have ~30 degrees Fahrenheit on average.
And it hasn't done any of that a few years before. 2 to 3 years ago I rebuilt the ingnition and fuel systems so I think I can get those out of the way. If there are things I can check before rebuilding it - what would I do that would tell the most other than cylinder pressure? I would gladly make some tests to avoid a rebuild. Thanks.
[This message has been edited by cebix (edited 12-11-2018).]
do a vacuum test if I were you. A compression test will not tell you as much if that's the symptoms you're having. If you don't know any mechanics with one, ask any motorcyclist friends, they use them for balancing carbs. Download a guide from the Web on how to use one. Gives a very accurate condition of bore wear and let's you know if you have any valve or head problems. I suspect you may have a blown or leaking head gasket. They don't always cause the oil or water to mix. They can leak water into the chamber, which causes uneven running, water consumption and white smoke in the exhaust
Yes, that will do it. run through all the tests it will list in the instruction.
Vacuum tests are generally a little more sensitive and can often be informative than compression testing, since the engine is actually running when you carry it out. You want a nice steady vacuum reading at idle with no fluctuation.
I have a friend flying over tomorrow, I'll see if he has space for any parts I have lying about. no use to me
Loosen and clean the threads on the plugs before the vacuum test, reinstall, but only tight enough that they seal. Get fully up to temperature. Conduct all the vacuum tests in the instruction sheet/card and note the readings as you do them. Let the engine idle a couple of mins. Switch off and remove all plugs as quickly as you can. Watch for any steam coming out of the plug holes. Because the coolant system is up to temp and pressurised, water will be forced into the chamber if the gasket is leaking slightly. Doesn't work if the gasket is leaking badly enough that the oil and water are mixing, but can be quite spectacular if only a slight leak into the chamber.
Do make sure that all the manifold hoses are clear of residue.
Where I’m from a vacuum test is a gauge you hook up to the base of the TB or carb to test the vacuum of the engine, it’s usually used for tuning pourposes, not engine general health. It’s the same gauge you use to setup multi cab setups on an outboard (well familiar with this).
However from the additional comments you made it almost sounds like you are talking about a leak down test?!?!?!?!
If you don’t mind could you explain in more detail for your friends in the US? Simply confused as to what you are suggesting for a test procedure...I’ve heard of doing a vacuum test on an engine before, however that was specific to a two cycle engine to crank case seal and reed flutter.
Ok so it’s the same thing I use for tuning carburetors. I was imagining a more involved test.
I’ve never used them to diagnose internal engine problems myself, I have compression, leak down and coolant pressure tests for that, but if it can be used accurately in that manner it would be awesome for folks without the funds to buy the more specific tools.
So the question now is... where do you plug it in the '85 2.5 TBI? There doesn't seem to be a fitting for this kind of thing. Should I unplug one of the vacuum lines?
