Ive been looking ( forgive me if I'm beating a dead horse) but I'm looking to see if anybody is making a direct bolt on kit yet to convert the rear of my car to 5x4 3/4 without the use of adapters. Most threads I've found but google search are archived and done 10-12 years ago nothing new. I only need to do the rear due to track width issues. The front of my car is full custom chassis and the rear is the only thing using the Fiero cradle.
I'm not sure it's only the cradle under the car attached to the custom chassis. How can I tell what year the cradle is under it? I'd post pictures of what I'm working on but can't find a place to upload
Is there a lower a-arm holding the wheel in place (84-87) or is there a 3 link setup with 2 parallel links going from the wheel to the cradle and the 3rd link going from the wheel to the front mounting location of the cradle (88).
Yes only option for me with the OE Lamborghini wheels is to change the wheel pattern or else I get the wrong rear width like I have now. I'm going to try to post a picture from my Photobucket not sure if it will work or not
Rear: Convert to Pontiac 6000 uprights with the HD brakes and 5x114.3 wheel pattern. Then with some minor grinding and slotting of holes you can install the Front wheel bearings from a mid 80s 4x4 S10 which have the 5 x 4 3/4". //www.fiero.nl/forum/F.../HTML/000007-19.html
I just seen they must have closed, November he was selling everything out. I did messages them just in case! Thanks for the responses. This has to get fixed so whatever direction I go has to be done. Cost isn't an issue but time is.
