Yeah, I understand how to compute pulley speeds, but unfortunately no matter how much math I do about pulleys all I could ultimately do is guess. I don't know what the car's consumption is, best or worst case, so ensuring the alternator's output is X amps doesn't really help me.
Truly, I don't care if the alternator never makes full output, all I need it to do is make enough. All else being equal, underdriving it does make some sense - 80a was doing the job just fine, so I have no need of the full 105a output of the CS130.
My hope was only to replicate the factory setup, assuming that GM had done its homework. The choice is '87 SI pulley or '88 CS pulley, smaller vs. larger respectively. My assumption is that the crank pulley did not change between '87 and '88. If that's true, then I can also assume the pulley that came on the alternator is the correct one. Additionally, since we know the CS makes more amps at a lower rpm, it certainly stands to reason there is no need to drive it at the same speed as the SI.
I'm gonna run the larger pulley and watch the voltmeter. Worst case, I call AAA and swap a pulley.
[This message has been edited by thesameguy (edited 04-18-2018).]
