  4.9 connector....What is it?
4.9 connector....What is it? by Spadesluck
Started on: 04-01-2018 05:10 PM
Replies: 3 (161 views)
Last post by: olejoedad on 04-01-2018 10:20 PM
Spadesluck
Report this Post04-01-2018 05:10 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
What was this connector to originally? This is my parts car that has a Fiero Factory 4.9 swap in it.
Total ratings: 207
Report this Post04-01-2018 07:47 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Looks like EVAP
Spadesluck
Report this Post04-01-2018 08:53 PM Click Here to See the Profile for SpadesluckSend a Private Message to SpadesluckEdit/Delete MessageReply w/QuoteDirect Link to This Post
Was hoping you saw this Joe. I can only assume its not needed then? I do not currently run EVAP.
Total ratings: 207
Report this Post04-01-2018 10:20 PM Click Here to See the Profile for olejoedadSend a Private Message to olejoedadEdit/Delete MessageReply w/QuoteDirect Link to This Post
Not needed, you can use the OEM Fiero charcoal canister, two small vacuum ports on passenger side bottom of 4.9 throttle body will actuate vacuum valve.
