  2.5 THROTTLE BODY REPAIR ?
2.5 THROTTLE BODY REPAIR ? by Lou6t4gto
Started on: 03-03-2018 03:59 PM
Replies: 3 (258 views)
Last post by: Lou6t4gto on 03-05-2018 01:49 PM
Lou6t4gto
Report this Post03-03-2018 03:59 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
IS a" throttle body re-bushing kit" available for a 1985 2.5 ? Shaft seems to be sloppy and was hoping to fix it. I've gotten the kits for other carbs like Quadra -Jet (comes with a drill Bit / Reamer and bushings). Can this be had for a 1985 2.5 (I think it's a "300" ? Thanks
Total ratings: 291
Report this Post03-03-2018 08:06 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Does the sloppyness bother you? Since the Fiero fuel injection is controlled by the MAP sensor, the engine does not lean out with a leak around the throttle valve. So unless the slop is a problem otherwise, it won't make it drive better.
Lou6t4gto
Report this Post03-03-2018 10:41 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
trying to "rule out" anything that could possibly make it NOT " Idle like New in gear". and whats left that is Not Brand New, the list is getting very small. LOL
Lou6t4gto
Report this Post03-05-2018 01:49 PM Click Here to See the Profile for Lou6t4gtoSend a Private Message to Lou6t4gtoEdit/Delete MessageReply w/QuoteDirect Link to This Post
tightening the 2 torx screws that hold the throttle body" halves" together, not the lid, seems to have made an enormous difference. Maybe....... LOL time will tell.
