  Current state of the art for F23 swap
Current state of the art for F23 swap by Will
Started on: 02-12-2018 09:26 PM
Replies: 5 (896 views)
Last post by: hiwil88formula on 02-14-2018 12:56 AM
Total ratings: 236
Report this Post02-12-2018 09:26 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
What's the current state of the art for an F23 swap?
At one point, Thelin's mount brackets and shift linkage were available for purchase, but his website is down.
Does anyone else make F23 mount brackets? Shift linkage?
I know it uses the same axles as the 282 and requires a specific clutch, although it has a deeper bellhousing than the 282.
I intend to mate it to a 3900.
wftb
Report this Post02-12-2018 10:47 PM Click Here to See the Profile for wftbSend a Private Message to wftbEdit/Delete MessageReply w/QuoteDirect Link to This Post
Roger Thelin is selling stuff in the mall. He sells a shifter kit as well. Shoot him a PM.
Blacktree
Total ratings: 350
Report this Post02-13-2018 09:11 AM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Leukay
Report this Post02-13-2018 12:51 PM Click Here to See the Profile for LeukaySend a Private Message to LeukayEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll chime in as I am going through this project as we speak. I ordered Roger's trans bracket kit but he was unable to provide a front bracket for my specific transmission (2002 cavalier w/2200 engine). Thankfully I was able to use his rear bracket, so I am getting ready to fabricate the front bracket mount since everything is now located by the engine mount and the rear trans mount.
I'm going to be fabricating the shifter cable mounts as well, using cables from California push pull.
I can't speak to the 3900 engine mount though. I'm using a 3800 and I believe I'm using the WCF engine mount (not 100% sure).
Total ratings: 236
Report this Post02-13-2018 08:07 PM Click Here to See the Profile for WillSend a Private Message to WillEdit/Delete MessageReply w/QuoteDirect Link to This Post
I'll be in that situation, as I'll need to start with that trans and swap its bellhousing onto a Cobalt XE transmission.
hiwil88formula
Report this Post02-14-2018 12:56 AM Click Here to See the Profile for hiwil88formulaSend a Private Message to hiwil88formulaEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have this setup in my car. The 3900 is nice and the f23 holds the power well. The gear ratios suck first gear is good to about 12-15mph. Had to fab the front bracket but I used Rogers rear bracket. If bvmotorsports is still selling the shift linkage buy it, don’t waste any time trying to fab your own. His design works like a charm.
