I have a 1984 Fiero SE with A/C. While driving it, the radio started to flicker on and off rapidly before dying out completely. This was accompanied by some sort of clicking noise coming from behind me. Not sure what it was but my gauge cluster and engine were still running fine. Fast forward to the next morning, start up the car fine, but I find out that NOTHING electrical works now! (Headlights, brake lights, marker lights, interior lights, hazards, windshield wipers, basically everything except reversal lights.) My needles on the gauge cluster still operate and the car is able to drive like a champ.
I have checked the fuses and they all look fine. Have not yet checked the battery, alternator is brand new and I have rewired and replaced temp sensors in the engine compartment. Does anyone know where I need to start looking? Electrical isn't really something I'm too comfortable to play with as I am still learning to work on cars in general. Any advice is much appreciated. I have a few issues I am still working on but this has me at a complete standstill.
I've jacked up the '84 and taken a look at the starter. I can't figure out a proper way to get to it but upon looking at it, there seems to be a cable that looks like it has split in half and is disconnected. I will have to try and get a picture but I just cant seem to get a good view on it.
What is the best way to reach the starter? I read in the Haynes manual (Waiting on my factory service manual to come in) that I need to remove the Cat Converter splash shield. What is that and how do I remove said shield?
From what I saw, I saw 3 wires to the Starter. There was a reddish wire, a cable wrapped in foil (positive battery cable?) and then a wire that may or may not have been wrapped in electrical tape that was exposed at the ends. They were close together but disconnected. Probably corroded away and sparked itself to a cut. I just need to get closer to the starter so I can get a better view.
If you don't know about fusable links, do some searching here on PFF. It's important to get that replaced properly and track down the source of the power drain.....(possibly the headlight motors).
Disconnect the Battery! If you short the starter end of battery cable then the battery can dump 300+ amps and make bigger problems and even cause a fire or explosion.
84 Fusible Links can and will die of "old age" alone because insulation get "old" by heat from cat etc then "water" will "eat" the wire inside. So you still need to check for other wiring problems but very likely you find nothing wrong for any car w/ same FL setup. I and many others fix many old GM cars for same problem and why GM moved them starting ~85.
To check FL loads is best to buy/rent/borrow AC/DC Amp Clamp meter. Many Clamps only read AC current on the Clamp but they do make DC units too. Look to spec etc for a meter... DC Amps ≥100a, many are ≥300a, is read by clamps. 10-20a only then is using a "shunt" inside and likely too small to read FL loads when HL Blower etc are on.
You do not need to remove the starter. only a nut on the solenoid. Do Not twist the "bolt' there. Twisting can wreck the solenoid contact inside. Often can reach solenoid bolts from the top. many pull left side cover/vent to get more room.
I was finally able to get a view on them. Looks like both my wires on the top bolt of the solenoid are bad. You can see the one that is broken in the images.
Now I just got to figure out what type of wire or fusible link, where its going, and where to find said wires.
I found new fusible links and I feel like I'm prepared now to replace the links. Can anyone tell me where I need to cut? I'm going to solder the link to some wire outside of the car, then splice the wires together. I'm running off the diagram from my factory manual that just came in, but I want to make sure I do it right. Any help is appreciated.
According to the Metric to AWG conversion chart, a 16 gauge wire is the closest match, but according to The Ogre's replacement chart, you have to use an 18 to replace a metric 1?
The factory manual state that both fusible links that attach to the starter solenoid are metric 1. I ordered two 16 gauge links but it looks like I need AWG 18?
I ordered the wrong fusible links. Waited another week for the correct gauge links, now the ring connector doesn't fit on the bolt on my starter solenoid.
Do you guys know where I can find a proper fusible link? I feel like I have searched everywhere.
Thank you all for you your help! I managed to find some links at Napa, slid them right on and the car is back to life. All electronics back as they were before.
The wires look and feel like they've been burnt to a crisp, which makes me think there is an exhaust leak. I wonder if that has anything to do with the popping I'm hearing, but that will be another thread for another day.
