  87 2.5 Timing
87 2.5 Timing by 16austin16
Started on: 01-20-2018 06:23 AM
Replies: 4 (217 views)
Last post by: theogre on 01-21-2018 12:27 AM
16austin16
Report this Post01-20-2018 06:23 AM Click Here to See the Profile for 16austin16Send a Private Message to 16austin16Edit/Delete MessageReply w/QuoteDirect Link to This Post
How would I adjust the timing let alone check it because Is hard see the crank from the top of the engine. Just wondering. I wanted to check it.
[This message has been edited by 16austin16 (edited 01-20-2018).]
da.slyboy
Report this Post01-20-2018 10:33 AM Click Here to See the Profile for da.slyboySend a Private Message to da.slyboyEdit/Delete MessageReply w/QuoteDirect Link to This Post
It helps to first clean off the timing tab then get some white chalk then rub it on the marks and the timing groove on the crank. timing light then makes those marks glow like Christmas lights.
Total ratings: 290
Report this Post01-20-2018 06:23 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
There is no adjusting the timing of the 87/88 2.5
Blacktree
Total ratings: 350
Report this Post01-20-2018 07:11 PM Click Here to See the Profile for BlacktreeClick Here to visit Blacktree's HomePageSend a Private Message to BlacktreeEdit/Delete MessageReply w/QuoteDirect Link to This Post
Phonedawgz is correct. The ignition timing on that engine is not adjustable. There's a disc built into the crankshaft with notches on it. Those notches are used to determine ignition timing.
Also, since the base timing is built into the crankshaft, it's practically impossible for the base timing to be wrong.
[This message has been edited by Blacktree (edited 01-20-2018).]
Total ratings: 568
Report this Post01-21-2018 12:27 AM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Correct you can't adjust timing and also you can't view timing either because no marks on crank pulley.
You can't really see timing w/ an ECM scanner because timing is too fast for data steam to OBD1 scanners. ECM can/will change timing for each spark.
go and read my links in your code 42 https://www.fiero.nl/forum/Forum2/HTML/140801.html
http://arrc.ebscohost.com/e..._IGNITION_SYSTEM.htm diagrams is for V6 but sim to L4.
