V-6 TIMING by RPYRAZOO
Started on : 01-15-2018 01:39 PM
Replies : 14 (397 views)
Last post by : Patrick on 02-12-2018 11:48 AM
Jan 15th, 2018
RPYRAZOO Member Posts: 457 From: BUFFALO, NY Registered: Aug 2006
What is the purpose of using a paper clip in the ECM port? Thanks for your info.
01:39 PM
tuggajb Member Posts: 74 From: mesa az Registered: Aug 2010
Shorts out the computer induced timing
01:52 PM
Jan 16th, 2018
Thanks, but is it a necessary step to correct timing? R
11:10 AM
Patrick Member Posts: 36403 From: Vancouver, British Columbia, Canada Registered: Apr 99
It's necessary step if you're using a timing light to set the ignition timing. Why do you ask?
11:38 AM
Blacktree Member Posts: 20770 From: Central Florida Registered: Dec 2001
If you're trying to set the distributer correctly, then yes you need to bypass the computer-controlled timing advance. That's what the paperclip is for. With the paperclip installed, ignition timing should be at or near 10° BTDC. If it's not, then adjust the distributer until it is. Then remove the paperclip, and you're done.
01:28 PM
Thank you for the explaination. When my mechanic wants to know why do I have to do such a wierd thing just to time the engine I'll have an answer. R
05:50 PM
No problem. If your mechanic is familiar with GM HEI ignition, then he shouldn't have any trouble with it.
10:47 PM
If your mechanic is an old guy, tell him that inserting the jumper is similar to disconnecting a distributor's vacuum advance prior to doing the timing.
11:22 PM
Jan 17th, 2018
Patrick: Now THAT'S something I remember my Father doing to his '65 Buick Electra 225!
09:09 AM
quote Originally posted by RPYRAZOO: Patrick: Now THAT'S something I remember my Father doing to his '65 Buick Electra 225!
Exactly... it's an old guy thing.
01:31 PM
Feb 9th, 2018
NiotaFiero Member Posts: 216 From: Niota,Tn. Registered: Nov 2007
If you’re trying to set it by ear then you don’t use the paper clip, right?
12:17 PM
quote Originally posted by NiotaFiero: If you’re trying to set it by ear then you don’t use the paper clip, right?
Correct.
12:58 PM
And after you do that, it might be a good idea to do the "paperclip trick" and use a timing light to see where the base timing ended up.
04:49 PM
Feb 12th, 2018
2.5 Member Posts: 43225 From: Southern MN Registered: May 2007
quote Originally posted by Blacktree: And after you do that, it might be a good idea to do the "paperclip trick" and use a timing light to see where the base timing ended up.
...although if the outer ring of the harmonic balancer has spun, the timing will
appear to be way off.
11:48 AM
