  fuel line help
fuel line help by Ducati 916
Started on: 11-17-2017 03:49 PM
Replies: 3 (117 views)
Last post by: Domtech on 11-17-2017 04:37 PM
Ducati 916
Report this Post11-17-2017 03:49 PM Click Here to See the Profile for Ducati 916Send a Private Message to Ducati 916Edit/Delete MessageReply w/QuoteDirect Link to This Post
A little help here for fuel line set up. Ive got a 1999 L67 with aeromotive fuel rails, how do I plumb this into the fiero fuel system? Do I need a return line or not?
Domtech
Report this Post11-17-2017 03:57 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
Yes, you will need a return line. The regulator must be after the fuel rail.
There are two options:
1. Have the fuel go thru the rail and then to the regulator.
2. Have the fuel rail tee off of the line going to the regulator.
You must use a vac/boost referenced regulator with the outlet going to the tank return.
Some regulators meant for option 2 already have a tee built in and have 3 ports, one in from the pump, one out to the rail, and one out to the tank return.
Hope that info helps.
Ducati 916
Report this Post11-17-2017 04:02 PM Click Here to See the Profile for Ducati 916Send a Private Message to Ducati 916Edit/Delete MessageReply w/QuoteDirect Link to This Post
Ok so I need to run a line from the tank to both fuel rails, then both back out into a regulator, then back to the tank. Is this correct?
Domtech
Report this Post11-17-2017 04:37 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
There are a lot of options for how you hook up the 2 rails to each other. That part isn't as important as the regulator routing.
There's a recent thread with some diagrams and more info here.
