Hi I have a 86 fiero v6 that i am converting to a digital gauge set up tach and speedo and one multi gauge for fuel ,temp .oil i have different warning lights that i want like temp,ck engine,door,oil, hazard how can i set this up with a terminal block at the back of the gauge pod? i am basically having a new gauge pod set up.
Terminal blocks are so messy. I would buy a crimper, and do the crimp and poke connectors. If you are very careful, you can make it so that the new one plugs in, and you can pull that out and put the original in. Be careful, the Fiero IP speedo divides the VSS by 2 and delivers it to the cruise and ECM.
Well right now i have mechanical after market gauges wired outside a pod for my project car my dash is all apart for a new dash. If anyone has a diagram please send me a pm on how to wire up three different gauges 2 intellitronix gauges tach and speedometer and one Dakota multi gauge for fuel ,temp and oil to work with the warning lights
