  Parking brake stuck
Parking brake stuck by 16austin16
Started on: 11-16-2017 04:04 PM
Replies: 3 (106 views)
Last post by: theogre on 11-16-2017 05:06 PM
16austin16
Report this Post11-16-2017 04:04 PM Click Here to See the Profile for 16austin16Send a Private Message to 16austin16Edit/Delete MessageReply w/QuoteDirect Link to This Post
So I tried to look around and didn't really find anything with my issue. When I try to pull my e brake the lever won't go up at all like it's stuck on something and I don't want to pull it too hard and break something. It would be helpful to have it working so I can leave my car running to warm up and not have to worry if it's going to roll. It's a 87 4cyl
Total ratings: 458
Report this Post11-16-2017 04:16 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
When's the last time you used it? Perhaps the cables are corroded/stuck. Back off the adjuster nut and see if anything moves.
16austin16
Report this Post11-16-2017 04:31 PM Click Here to See the Profile for 16austin16Send a Private Message to 16austin16Edit/Delete MessageReply w/QuoteDirect Link to This Post
I'll have to take a look but I know it sat for 2 years before I bought it and it's never worked
Total ratings: 568
Report this Post11-16-2017 05:06 PM Click Here to See the Profile for theogreClick Here to visit theogre's HomePageSend a Private Message to theogreEdit/Delete MessageReply w/QuoteDirect Link to This Post
Likely cables frozen or rusted.
Iffy caliper often let lever move but do little or nothing.
loosen adjust nut if you can just to see what cables are bad. At minimum replace wheel cables. Their likely bad even if they work. Rust can make the jacket to break at end(s).
