If AC needs 32a then 100A alt maybe too small. Remember 100a is only the Peak output and likely will have problems driving in the city or 5th gear cruising, worse city et al at night w/ lights on. Sim to "power pulley" problems that some have.
See my Cave,
Watt StoryHigher alt often = bigger size and bigger alts might not fit in a Fiero. Even
"iceberg" CS130 cases have problems in some setups. Example: Fins hit intake manifold for 87-88 L4.
| quote | Originally posted by phonedawgz: Yeah, it would be a whole lot cheaper to put a stock AC system on a Fiero than it would be to do an aftermarket. |
Plus you don't need to design new AC evap box etc. Just an Aftermarket Evap and it's box/ducts can eat a lot of space you don't have in a Fiero.
Problem is AC is built into at least 200 and 500 zones, cabin and engine wiring. AC is wired to ECM too. To "direct" swap the donor would need V6 w/ same trans minimum.
If donor isn't exact match then very carefully cutting out AC wiring isn't fun.
either way is not easy to do this.
