Just picked up a Fiero ( 2.8V6 4spd) and wanted to drop in 3.1 from a 2001 Malibu. I read another thread about the 3.1 from a regal, just wondering if anybody has tried with the newer motor?
There's also the 3.4L out of the grand-am/Alero/several others.
Plenty of people have done the swap. It bolts right in with stock mounts, other than the dog bone. You'll need a neutral-balanced flywheel for a manual trans, either from a later Fiero or one of many 4 and 6-cylinders thereafter. Plumbing is a bit different. And you need to run a reprogrammed ECM and set up the wiring harness.
There are a few threads on here regarding the swap. If you can't find any for the "3100" engine, look for ones for the "3400" engine. Basically the same engine.
