  Allante Intake Installation
Allante Intake Installation by 87convert
Started on: 07-11-2017 12:17 AM
Replies: 2 (234 views)
Last post by: 87convert on 07-13-2017 01:26 AM
87convert
Report this Post07-11-2017 12:17 AM Click Here to See the Profile for 87convertSend a Private Message to 87convertEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have two interference's regarding the install of my Allante intake. First, as shown in the picture below, the TPS sensor attach fasteners are riding hard against the trunk wall. Second, the throttle spacer/heater rides hard against the rear rocker cover. Has anyone else has these issues? I think a ball peen hammer can fix the first issue. Do I need to buy an Allante rear rocker cover to fix the second issue?
Rolland
Total ratings: 460
Report this Post07-11-2017 10:53 AM Click Here to See the Profile for RaydarSend a Private Message to RaydarEdit/Delete MessageReply w/QuoteDirect Link to This Post
Wow! I didn't have those clearance issues. Either of them. I left my spacer in place, but I think I may have removed the pipes from it.
If you install the spacer, it will likely eliminate the clearance problem between the TPS and the trunk wall.
87convert
Report this Post07-13-2017 01:26 AM Click Here to See the Profile for 87convertSend a Private Message to 87convertEdit/Delete MessageReply w/QuoteDirect Link to This Post
Found the problem with the spacer/throttle body heater. The hose clamps on the hoses were below the hoses interfering with the rocker cover. Once I removed them the spacer fit just fine.
Also once the spacer was in place, the clearance for the throttle position sensor attach bolts was significantly improved. No problem now.
Rolland
