  Popping back thru throttle body
Popping back thru throttle body by DirtyDawg
Started on: 06-18-2017 01:54 PM
Replies: 16 (510 views)
Last post by: sardonyx247 on 07-12-2017 08:16 AM
DirtyDawg
Report this Post06-18-2017 01:54 PM Click Here to See the Profile for DirtyDawgSend a Private Message to DirtyDawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Can't seem to figure out, car ran great then all of a sudden you can't give it any gas it just pops back thru throttle body and want idle, starts up. 2.8 has done this in the past but would clear out. Looking for suggestions, Thanks
tyro_2004_2004
Report this Post06-18-2017 04:18 PM Click Here to See the Profile for tyro_2004_2004Send a Private Message to tyro_2004_2004Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had this happen to me last year. I had to replace the Throttle position sensor and that fixed the issue. I hope that helps!
tyro_2004_2004
Report this Post06-18-2017 04:20 PM Click Here to See the Profile for tyro_2004_2004Send a Private Message to tyro_2004_2004Edit/Delete MessageReply w/QuoteDirect Link to This Post
tyro_2004_2004
Member since Apr 2015
DirtyDawg
Report this Post06-18-2017 05:15 PM Click Here to See the Profile for DirtyDawgSend a Private Message to DirtyDawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
That's what I thought, replaced that first, didn't help also tried another coil, didn't help. Thinking maybe Ign. mod. Also changed rotor button and cap. Can't figure it out.
Thanks for the reply
cebix
Report this Post06-18-2017 06:12 PM Click Here to See the Profile for cebixSend a Private Message to cebixEdit/Delete MessageReply w/QuoteDirect Link to This Post
Any ECM codes stored? Check engine light came on?
La fiera
Report this Post06-18-2017 06:40 PM Click Here to See the Profile for La fieraSend a Private Message to La fieraEdit/Delete MessageReply w/QuoteDirect Link to This Post
How did it happened? Was the car running when it happened?
DirtyDawg
Report this Post06-18-2017 06:42 PM Click Here to See the Profile for DirtyDawgSend a Private Message to DirtyDawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Going to have to put a new bulb in check engine light, I guess, it's not on. Unhooked battery cable to reset computer still have the same problem.
Thanks for reply
DirtyDawg
Report this Post06-18-2017 06:47 PM Click Here to See the Profile for DirtyDawgSend a Private Message to DirtyDawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
DirtyDawg
Member since May 2014
Yes car was running, was driving home under a pull up hill. Did it before and I just let off pedal and it smoothed back out, didn't do it for several months, now it want smooth out. Bought a Ing. Mod. going to try it when it gets here.
Thanks for reply
tyro_2004_2004
Report this Post06-19-2017 12:22 AM Click Here to See the Profile for tyro_2004_2004Send a Private Message to tyro_2004_2004Edit/Delete MessageReply w/QuoteDirect Link to This Post
I hope the new ICM works for ya. Please keep us posted on the results.
tyro_2004_2004
Report this Post06-19-2017 12:24 AM Click Here to See the Profile for tyro_2004_2004Send a Private Message to tyro_2004_2004Edit/Delete MessageReply w/QuoteDirect Link to This Post
tyro_2004_2004
While your waiting for the ICM. You should check all your vacuum lines for leaks.
[This message has been edited by tyro_2004_2004 (edited 06-19-2017).]
lou_dias
Total ratings: 67
Report this Post06-20-2017 06:27 PM Click Here to See the Profile for lou_diasSend a Private Message to lou_diasEdit/Delete MessageReply w/QuoteDirect Link to This Post
Maybe the nut on the distributor got loose and your timing is off...
DirtyDawg
Report this Post07-05-2017 05:43 PM Click Here to See the Profile for DirtyDawgSend a Private Message to DirtyDawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Well, ICM didn't fix it, distributor bolt is tight, can't move dist. just about ready to get rid of it.
shemdogg
Report this Post07-05-2017 06:46 PM Click Here to See the Profile for shemdoggSend a Private Message to shemdoggEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your fuel pressure, have you changed the fuel filter? Sometimes its worth taking it in to a good mechanic. I took mine in to have the timing set(i couldnt get it) and the injectors cleaned. Car runs like a champ now
good luck
shem
DirtyDawg
Report this Post07-05-2017 08:34 PM Click Here to See the Profile for DirtyDawgSend a Private Message to DirtyDawgEdit/Delete MessageReply w/QuoteDirect Link to This Post
Since I've owned it I have put new fuel pump, new fuel sending unit, new fuel filter, new bosh fuel injectors has ran good for past 2 yrs. getting frustrated, going to pull valve covers next when I get motivated.
Total ratings: 291
Report this Post07-05-2017 08:51 PM Click Here to See the Profile for phonedawgzClick Here to visit phonedawgz's HomePageSend a Private Message to phonedawgzEdit/Delete MessageReply w/QuoteDirect Link to This Post
Check your fuel pressure with a gauge. See what it does when you try revving the engine. Many times parts stores let you borrow one. Make sure it is for a fuel injected vehicle and can read up to 60 psi and has a thread on connection.
[This message has been edited by phonedawgz (edited 07-05-2017).]
T4Turtle
Report this Post07-11-2017 04:45 PM Click Here to See the Profile for T4TurtleSend a Private Message to T4TurtleEdit/Delete MessageReply w/QuoteDirect Link to This Post
Popping through intake can be a lea condition do checking fuel pressure under load is a good idea.
Also it could be the distributor is just too worn out. Just went through this on my 1993 Jeep XJ and the rotor was hitting the pickup every once in a while, then got worse. This was also a newer re-manufactured distributor.
1987 GT TPI
sardonyx247
Total ratings: 219
Report this Post07-12-2017 08:16 AM Click Here to See the Profile for sardonyx247Click Here to visit sardonyx247's HomePageSend a Private Message to sardonyx247Edit/Delete MessageReply w/QuoteDirect Link to This Post
I had this happen on my first Fiero, everything says timing, but the 88s (duke) are not adjustable.
I put on some GOOD spark plug wires and totally went away.
By GOOD I mean low ohm spiral wrapped core wires, like Taylors are now.
Edit to add: I see its a 2.hate, see if your EGR tube has cracked, very common problem.
"DRIVE IT LIKE A FIERO"
'87 Quad 4 H.O.
Now on my 11th Fiero
[This message has been edited by sardonyx247 (edited 07-12-2017).]
