Does anyone have the information for PRE 88 Spring Codes, Part Numbers, And Specs?
Like for example I have a lot of info for the 88 springs.. but what about pree 88?
88 FRONT springs (ARB, ARC, ARD, FPH, FPJ) was 205.5 lbs/in, mfg tolerance plus or minus 3%
Part # CODE
10048402 FPJ (Longest Spring)
10048401 FPH
10068654 ARD (12.31 inches)
10068653 ARC
10068652 ARB (Shortest Spring)
Specs for the ARD and PUC springs, converted from metric values.
ARD: 88 Front
Wire diameter: 0.493"
Coil diameter: 3.881"
Free height "S": 12.31"
Active coils (@ free height "S"): 6.94
Active coils (@ height "L"): 6.48
Load @ height "L" (7.87 in): 912.7 lbs
Design rate @ height "L": 205.5 lbs/in
Calculated rate using "free height" active coils: 205.1 lbs/in
Calculated rate using height "L" active coils: 219.6 lbs/in
^ The above info i have from a text file saved years ago. Data mostly from Guru.
Id like to compile a file for pre 88 springs. Any data would be much appreciated. Thanks.
[This message has been edited by SP1200 (edited 06-18-2017).]
