  Monsoon Amp wire Questions
Monsoon Amp wire Questions by Inferno
Started on: 06-15-2017 12:12 PM
Replies: 2 (178 views)
Last post by: 1986 Fiero GT on 06-15-2017 01:56 PM
Inferno
Report this Post06-15-2017 12:12 PM Click Here to See the Profile for InfernoSend a Private Message to InfernoEdit/Delete MessageReply w/QuoteDirect Link to This Post
For those that are in the world of knowledge when it comes to the Monsoon Amplifiers.
I am installing a Monsoon Amp into a my 88 Fiero with an aftermarket Head Unit.
I have the wiring diagram for the amplifier. From Both the F-Body and Grand Am and they are the same for the most part regarding my questions.
I have two questions;
1- Purple Wire to the Amp says "Gain Control Signal", do I need that? and if so what do I hook that to on the new Head Unit?
2- Dark Green Wire to the Amp says "Amp Control", do I need that? and if so what do I hook that to on the new Head Unit?
Amplifier is from an 04 Grand Am GT
Thanks for your assistance.
Inferno
Report this Post06-15-2017 01:50 PM Click Here to See the Profile for InfernoSend a Private Message to InfernoEdit/Delete MessageReply w/QuoteDirect Link to This Post
I may have figured out my own issue.
Dark Green Wire is connected to the remote power on.
The Gain Control can be connected to the factory performance sound gain control for the factory sub.
1986 Fiero GT
Total ratings: 54
Report this Post06-15-2017 01:56 PM Click Here to See the Profile for 1986 Fiero GTSend a Private Message to 1986 Fiero GTEdit/Delete MessageReply w/QuoteDirect Link to This Post
You figured it out.
The purple gain control wire is basically a remote volume control signal from the factory radio. Doesn't do you a whole ton of good. The dark green wire is your 12V turn-on signal. Connect that to the amplifier turn-on or amplifier remote wire from the radio.
