  Clutch not disengaging completely
Clutch not disengaging completely by LovesGoldens
Started on: 05-25-2017 11:17 AM
Replies: 5 (118 views)
Last post by: FIEROPHREK on 05-25-2017 08:51 PM
LovesGoldens
Report this Post05-25-2017 11:17 AM Click Here to See the Profile for LovesGoldensSend a Private Message to LovesGoldensEdit/Delete MessageReply w/QuoteDirect Link to This Post
I have replaced 3 each master and slave cylinders on my '88 Fiero 5 speed transmission. Clutch will not fully disengage.. Only get 3/4" movement on the slave. Tried different bleeding procedures with no effect. Am I getting the incorrect parts? What is the original bore dimensions of the cylinders?
Report this Post05-25-2017 12:21 PM Click Here to See the Profile for Gall757Send a Private Message to Gall757Edit/Delete MessageReply w/QuoteDirect Link to This Post
If you can pump the clutch pedal rapidly and get more travel at the slave, there is still air in the system. The getrag slave cylinder is fatter and shorter than the other slave cylinders. Your pushrod should only be about 3.5" long.
[This message has been edited by Gall757 (edited 05-25-2017).]
Rodney
Total ratings: 267
Report this Post05-25-2017 01:41 PM Click Here to See the Profile for RodneyClick Here to visit Rodney's HomePageSend a Private Message to RodneyEdit/Delete MessageReply w/QuoteDirect Link to This Post
Your clutch pedal should be about an inch above the brake pedal. If not the clutch pedal is bent. It typically bends in the steel U part on the top of the pedal.
Rodney Dickman
7604 Treeview Drive
Caledonia, WI 53108
Phone/Fax (262) 835-9575
Domtech
Report this Post05-25-2017 01:45 PM Click Here to See the Profile for DomtechSend a Private Message to DomtechEdit/Delete MessageReply w/QuoteDirect Link to This Post
First, which 5 speed? Getrag or Isuzu?
Second, you should do yourself a favor and use parts from Rodney, you will have more success.
Total ratings: 458
Report this Post05-25-2017 03:37 PM Click Here to See the Profile for PatrickSend a Private Message to PatrickEdit/Delete MessageReply w/QuoteDirect Link to This Post
Originally posted by LovesGoldens:
'88 Fiero 5 speed transmission... Am I getting the incorrect parts?
That's rather difficult for us to tell when you make no mention of which 5-spd tranny you have!
FIEROPHREK
Total ratings: 137
Report this Post05-25-2017 08:51 PM Click Here to See the Profile for FIEROPHREKSend a Private Message to FIEROPHREKEdit/Delete MessageReply w/QuoteDirect Link to This Post
I've had an instance where the pivot points for the pressure pate fingers where broken. This prevented the pressure plate from lifting off the clutch disc in the area where the pivots where broken. It's a little harder to diagnose but it could be a possible problem.
12.3 is faster than a 13.2
