Tunerpro RT and the 4.9 engine..... by MadProfessor8138
Started on : 04-10-2017 01:25 PM
Replies : 21 (475 views)
Last post by : MadProfessor8138 on 04-13-2017 06:31 PM
Apr 10th, 2017
MadProfessor8138 Member Posts: 351 From: Ekron,Kentucky Registered: May 2015
Has anyone used the Tunerpro RT program to scan their 4.9 ? I have a question that I can't seem to find the answer to....... Can anyone help ?
01:25 PM
Wow......Not one single person has an opinion on the subject ?!
On "THIS" forum.....
I should have bought a Lottery ticket on the way home today...lmao
[This message has been edited by MadProfessor8138 (edited 04-10-2017).]
09:40 PM
Neils88 Member Posts: 4058 From: Jeddore,Nova Scotia Registered: Aug 2013
No. Does that help?
09:52 PM
Well,there goes the lottery and my retirement.......lol
10:54 PM
Apr 11th, 2017
lou_dias Member Posts: 5382 From: Warwick, RI Registered: Jun 2000
There's an ADX file out there that lets you scan... Nothing that lets you read/write a .bin file though...
08:06 AM
gen2muchwork Member Posts: 861 From: dearborn, MI Registered: Feb 2012
I use it to scan/log on my 4.9. I'm just not good enough at it to probably be of any help
08:17 AM
I'm only looking to scan.....nothing more. The file is suppose to be on the disk but I'm having trouble finding which file needs to be loaded into the program..... I haven't been into computers for several years so I'm behind the curve right now...
09:10 AM
I have it at home on my laptop somewhere but if it was the .adx that you used last, it should come up by default - no?
10:50 AM
I've never used the program before.....I'm trying to figure out if I need to import the file to scan the engine,and if so,which file is for the 4.9 .....
10:55 AM
quote Originally posted by MadProfessor8138: I've never used the program before.....I'm trying to figure out if I need to import the file to scan the engine,and if so,which file is for the 4.9 .....
I'll try and take a look tonight on that laptop. I remember the first time I set it up I was confused how to load the file correctly, and which file to use... just like you are. I have not used it in a while, although I need to to log some data that I ment to last season. I might have seen a youtube out there on how to do it. I do have the file somewhere on that laptop I use as well, there are a few out there... one version worked better- less errors than others.
12:19 PM
Phonedawgz did some videos in a thread a few years back on how to use it...
12:43 PM
Glad I'm not the only one confused with the program... If you could guide me a little I would really appreciate it.... I've tried to get ahold of phonedawgz but haven't had much luck....
02:59 PM
I didn't find it at all intuitive. When you get things figured out, maybe you can put together a step-by-step guide (thread) for those of use that would really like to get into tuning.
07:23 PM
Maybe gen2muchwork could put something together for everyone....or maybe I could do it once he holds my hand through the learning process. It seems that I'm not the only one interested in this topic...
09:49 PM
Apr 12th, 2017
You can't tune a 4.9 with Tuner Pro because no one created a mapping file for it [.xdf]. You can SCAN with it because an .ads/.adx file exists.
Here it is. Just copy and paste this code into a file using a .adx extension then you can use it to scan a 4.9
code: <ADXFORMAT version="1.01"> <!-- Written 03/16/2011 19:13:14 --> <ADXHEADER> <guid>529ec065-8a62-4f2d-80f7-550684d8779b</guid> <flags>0x01</flags> <objectcount>141</objectcount> <author>Victor Seitz littleno200@yahoo.de</author> <baud>8192</baud> <DEFAULTS datasizeinbits="8" sigdigits="2" outputtype="3" baud="9600" signed="0" lsbfirst="0" float="0" /> <monitorcmd>COMMAND0MAC</monitorcmd> </ADXHEADER> <ADXMONITOR id="MONIMPORT" idhash="0xC5C183FF" title="Imported Mon"> <mainbkgcolor>0x00FFFFFF</mainbkgcolor> <plotbkgcolor>0x00F0F0F0</plotbkgcolor> <plotoutlinecolor>0x00000000</plotoutlinecolor> <titlecolor>0x00000000</titlecolor> <timeaxiscolor>0x00000000</timeaxiscolor> <entrycount>4</entrycount> <ADXMONSERIES linecolor="0x0000FF" axiscolor="0x0000FF" itemidhash="0xDE6A9730" /> <ADXMONSERIES linecolor="0x009600" axiscolor="0x009600" itemidhash="0xDE69CDB0" /> <ADXMONSERIES linecolor="0xFF0000" axiscolor="0xFF0000" itemidhash="0xDE6A30B0" /> <ADXMONSERIES linecolor="0xFF8080" axiscolor="0xFF8080" itemidhash="0xDE69DAD0" /> </ADXMONITOR> <ADXDASHBOARD id="DASHIMPORT" idhash="0x5D4D481F" title="Imported Dash"> <entrycount>6</entrycount> <ADXDGENTRY gaugetype="1" left="0" top="0" right="33" bottom="50" /> <ADXDGENTRY gaugetype="1" left="33" top="0" right="66" bottom="50" /> <ADXDGENTRY gaugetype="1" left="66" top="0" right="99" bottom="50" /> <ADXDGENTRY gaugetype="1" left="0" top="50" right="33" bottom="100" /> <ADXDGENTRY gaugetype="1" left="33" top="50" right="66" bottom="100" /> <ADXDGENTRY gaugetype="1" left="66" top="50" right="99" bottom="100" /> </ADXDASHBOARD> <ADXCSENDCOMMAND id="COMMAND0" idhash="0xC579AD33" title="Mode 1 ALDL stream request Send"> <bytestring size="0x5">F4570100B4</bytestring> </ADXCSENDCOMMAND> <ADXCLISTENPACKET id="COMMAND0RE" idhash="0xE6B79C55" title="Mode 1 ALDL stream request Reply" flags="0x00000005"> <listentimeout>400</listentimeout> <packetbodylength>51</packetbodylength> <packetoffsetinbody>3</packetoffsetinbody> <packetsize>48</packetsize> </ADXCLISTENPACKET> <ADXMACRO id="COMMAND0MAC" idhash="0xD685487C" title="Mode 1 ALDL stream request Macro" repeatcount="1"> <NODE commandID="COMMAND0" repeatcount="1" /> <NODE commandID="COMMAND0RE" repeatcount="1" /> </ADXMACRO> <ADXCSENDCOMMAND id="COMMAND1" idhash="0xC579A373" title="Clear Trouble Codes Send"> <bytestring size="0x4">F4560AAC</bytestring> </ADXCSENDCOMMAND> <ADXCLISTENPACKET id="COMMAND1RE" idhash="0xE68E9C55" title="Clear Trouble Codes Reply" flags="0x00000005"> <listentimeout>400</listentimeout> <packetbodylength>3</packetbodylength> <packetoffsetinbody>0</packetoffsetinbody> <packetsize>3</packetsize> </ADXCLISTENPACKET> <ADXMACRO id="COMMAND1MAC" idhash="0xD1A5487C" title="Clear Trouble Codes Macro" repeatcount="1"> <NODE commandID="COMMAND1" repeatcount="1" /> <NODE commandID="COMMAND1RE" repeatcount="1" /> </ADXMACRO> <ADXLOOKUPTABLE id="105" idhash="0xCD5217BB" title="temp Deg C"> <desc><Comments></desc> <inputtype>1</inputtype> <outputtype>3</outputtype> <lookupmode>0</lookupmode> <entrycount>39</entrycount> <tableentry input="1.000000" output="-40.000000" /> <tableentry input="5.000000" output="-30.000000" /> <tableentry input="6.000000" output="-25.000000" /> <tableentry input="9.000000" output="-20.000000" /> <tableentry input="11.000000" output="-15.000000" /> <tableentry input="15.000000" output="-10.000000" /> <tableentry input="19.000000" output="-5.000000" /> <tableentry input="25.000000" output="0.000000" /> <tableentry input="31.000000" output="5.000000" /> <tableentry input="38.000000" output="10.000000" /> <tableentry input="47.000000" output="15.000000" /> <tableentry input="57.000000" output="20.000000" /> <tableentry input="67.000000" output="25.000000" /> <tableentry input="79.000000" output="30.000000" /> <tableentry input="91.000000" output="35.000000" /> <tableentry input="104.000000" output="40.000000" /> <tableentry input="117.000000" output="45.000000" /> <tableentry input="130.000000" output="50.000000" /> <tableentry input="142.000000" output="55.000000" /> <tableentry input="154.000000" output="60.000000" /> <tableentry input="164.000000" output="65.000000" /> <tableentry input="175.000000" output="70.000000" /> <tableentry input="184.000000" output="75.000000" /> <tableentry input="192.000000" output="80.000000" /> <tableentry input="200.000000" output="85.000000" /> <tableentry input="206.000000" output="90.000000" /> <tableentry input="212.000000" output="95.000000" /> <tableentry input="217.000000" output="100.000000" /> <tableentry input="222.000000" output="105.000000" /> <tableentry input="226.000000" output="110.000000" /> <tableentry input="230.000000" output="115.000000" /> <tableentry input="233.000000" output="120.000000" /> <tableentry input="235.000000" output="125.000000" /> <tableentry input="238.000000" output="130.000000" /> <tableentry input="240.000000" output="135.000000" /> <tableentry input="242.000000" output="140.000000" /> <tableentry input="243.000000" output="145.000000" /> <tableentry input="244.000000" output="150.000000" /> <tableentry input="256.000000" output="200.000000" /> </ADXLOOKUPTABLE> <ADXVALUE id="2" idhash="0x86F34E3B" title="PROM ID"> <packetoffset>0x00</packetoffset> <sizeinbits>16</sizeinbits> <range low="0.000000" high="3.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>0</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="17" idhash="0xDE6A9730" title="engine RPM"> <units>RPM</units> <packetoffset>0x17</packetoffset> <range low="0.000000" high="6375.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 25.000000 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="18" idhash="0xDE6A9A70" title="speed MPH"> <units>MPH</units> <packetoffset>0x18</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>1</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="19" idhash="0xDE6A8D30" title="speed KPH"> <units>KPH</units> <packetoffset>0x18</packetoffset> <range low="0.000000" high="410.299988" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 1.609000 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="13" idhash="0xDE6A9BB0" title="TPS volts"> <units>volts</units> <packetoffset>0x16</packetoffset> <range low="0.000000" high="5.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 0.019600 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="16" idhash="0xDE6A8D70" title="TPS %"> <units>%</units> <packetoffset>0x16</packetoffset> <range low="0.000000" high="100.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="9" idhash="0x86F347BB" title="MAP volts"> <units>volts</units> <packetoffset>0x13</packetoffset> <range low="0.000000" high="5.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 0.019600 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="10" idhash="0xDE6A9050" title="MAP Kpa"> <units>Kpa</units> <packetoffset>0x13</packetoffset> <range low="20.400000" high="102.769997" /> <alarms low="20.400000" high="20.400000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 0.323000 + 20.400000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="26" idhash="0xDE69D970" title="barometric pressure volts"> <units>volts</units> <packetoffset>0x1F</packetoffset> <range low="0.000000" high="5.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 0.019600 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="29" idhash="0xDE69D930" title="barometric pressure Kpa"> <units>Kpa</units> <packetoffset>0x1F</packetoffset> <range low="20.400000" high="102.769997" /> <alarms low="20.400000" high="20.400000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 0.323000 + 20.400000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="3" idhash="0x86F3513B" title="coolant temperature"> <flags>0x00000004</flags> <units>Deg C</units> <packetoffset>0x0D</packetoffset> <range low="-40.000000" high="151.250000" /> <alarms low="-40.000000" high="117.500000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 0.750000 + -40.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="25" idhash="0xDE69DAD0" title="manifold temperature"> <units>Deg C</units> <packetoffset>0x1E</packetoffset> <range low="-40.000000" high="151.250000" /> <alarms low="-40.000000" high="-40.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 0.750000 + -40.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="8" idhash="0x86F350FB" title="battery voltage"> <units>volts</units> <packetoffset>0x12</packetoffset> <range low="0.000000" high="0.040000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="10.000000 / X + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="11" idhash="0xDE6A9E10" title="left front closed loop integrator"> <units>counts</units> <packetoffset>0x14</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>1</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="12" idhash="0xDE6A84B0" title="right rear closed loop integrator"> <units>counts</units> <packetoffset>0x15</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>1</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="30" idhash="0xDE6A2450" title="right block learn multiplier"> <units>counts</units> <packetoffset>0x22</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>1</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="31" idhash="0xDE6A2A10" title="left block learn multiplier"> <units>counts</units> <packetoffset>0x23</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>1</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="37" idhash="0xDE6A2330" title="BLM cell"> <units>counts</units> <packetoffset>0x2A</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="20" idhash="0xDE69C450" title="left injector pulse width"> <units>mSec</units> <packetoffset>0x19</packetoffset> <sizeinbits>16</sizeinbits> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="21" idhash="0xDE69CA10" title="right injector pulse width"> <units>mSec</units> <packetoffset>0x1B</packetoffset> <sizeinbits>16</sizeinbits> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="4" idhash="0x86F3533B" title="left O2 cross counts"> <units>counts</units> <packetoffset>0x0E</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>1</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="5" idhash="0x86F3445B" title="right O2 cross counts"> <units>counts</units> <packetoffset>0x0F</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>1</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="6" idhash="0x86F347FB" title="left O2 sens voltage"> <units>volts</units> <packetoffset>0x10</packetoffset> <range low="0.000000" high="1132.199951" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 4.440000 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="7" idhash="0x86F35DBB" title="right O2 sens voltage"> <units>volts</units> <packetoffset>0x11</packetoffset> <range low="0.000000" high="1132.199951" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 4.440000 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="38" idhash="0xDE6A2E70" title="desired idle speed"> <units>RPM</units> <packetoffset>0x2B</packetoffset> <range low="0.000000" high="6375.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 25.000000 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="24" idhash="0xDE69CDB0" title="spark advance"> <units>Deg</units> <packetoffset>0x1D</packetoffset> <range low="0.000000" high="89.650002" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 0.351560 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="32" idhash="0xDE6A30B0" title="EGR duty cycle"> <units>%</units> <packetoffset>0x24</packetoffset> <range low="0.000000" high="0.010000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="2.560000 / X + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="33" idhash="0xDE6A2FB0" title="EGR fuel compensation"> <units>%</units> <packetoffset>0x25</packetoffset> <range low="0.000000" high="0.010000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="2.560000 / X + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="39" idhash="0xDE6A3930" title="canister purge duty cycle"> <units>%</units> <packetoffset>0x2C</packetoffset> <range low="0.000000" high="0.010000" /> <alarms low="0.000000" high="0.010000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="2.560000 / X + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="34" idhash="0xDE6A2DB0" title="cruise control set speed MPH"> <units>MPH</units> <packetoffset>0x27</packetoffset> <range low="0.000000" high="255.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="35" idhash="0xDE6A3AD0" title="cruise control set speed KPH"> <units>KPH</units> <packetoffset>0x27</packetoffset> <range low="0.000000" high="410.299988" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="X * 1.609000 + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXVALUE id="36" idhash="0xDE6A3970" title="cruise control servo position"> <units>%</units> <packetoffset>0x28</packetoffset> <range low="0.000000" high="1.000000" /> <alarms low="0.000000" high="0.000000" /> <digcount>2</digcount> <outputtype>3</outputtype> <MATH equation="256.000000 / X + 0.000000"> <VAR varID="X" type="native" /> </MATH> </ADXVALUE> <ADXBITMASK id="118" idhash="0xCD53CB1B" title="closed loop status"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>closed</truestring> <falsestring>open</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x20</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="117" idhash="0xCD53C65B" title="right O2 rich/lean"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>rich</truestring> <falsestring>lean</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x21</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="145" idhash="0xCD532BBB" title="left O2 rich/lean"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>rich</truestring> <falsestring>lean</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x21</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="157" idhash="0xCD51DE5B" title="block learn mode"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>enabled</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2D</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="60" idhash="0xDE68FC50" title="Code 12 - No Distributor signal"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x02</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="59" idhash="0xDE689530" title="Code 13 - right O2 sensor not ready"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x02</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="58" idhash="0xDE688270" title="Code 14 - shortet coolant sens"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x02</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="57" idhash="0xDE688F30" title="Code 15 - open coolant sens"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x02</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="48" idhash="0xDE6A6E70" title="Code 16 - alt voltage out of range"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x02</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="49" idhash="0xDE6A7930" title="Code 17 - left O2 sensor not ready"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x02</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="50" idhash="0xDE688850" title="Code 18 - executive loop overrun"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x02</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="53" idhash="0xDE6883B0" title="Code 19 - shorted fuel pump circuit"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x02</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="54" idhash="0xDE6881B0" title="Code 20 - open fuel pump circuit"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x03</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="55" idhash="0xDE6896D0" title="Code 21 - shorted TPS circuit"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x03</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="62" idhash="0xDE68E8B0" title="Code 22 - open TPS circuit"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x03</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="63" idhash="0xDE68F7B0" title="Code 23 - EST/bypass circuit problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x03</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="64" idhash="0xDE68F5B0" title="Code 24 - speed sensor circuit"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x03</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="65" idhash="0xDE68E2D0" title="Code 26 - shorted throttle switch"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x03</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="66" idhash="0xDE68E170" title="Code 27 - open throttle switch"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x03</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="67" idhash="0xDE68FB30" title="Code 28 - open 3rd or 4th gear discrete"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x04</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="68" idhash="0xDE68F670" title="Code 29 - shorted 3rd or 4th gear switch"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x04</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="69" idhash="0xDE68E130" title="Code 30 - idle speed control circuit problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x04</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="74" idhash="0xDE6BBDB0" title="Code 31 - shorted MAP sensor"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x04</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="75" idhash="0xDE6BAAD0" title="Code 32 - open MAP sensor"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x04</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="82" idhash="0xDE6A08B0" title="Code 34 - MAP sensor signal too high"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x04</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="83" idhash="0xDE6A17B0" title="Code 37 - shorted MAT sensor circuit"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x05</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="84" idhash="0xDE6A15B0" title="Code 38 - open MAT sensor circuit"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x05</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="85" idhash="0xDE6A02D0" title="Code 39 - VCC engagement problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x05</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="86" idhash="0xDE6A0170" title="Code 40 - open P/S pressure switch circuit"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x05</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="87" idhash="0xDE6A1B30" title="Code 41 - CAM sensor circuit problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x05</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="88" idhash="0xDE6A1670" title="Code 42 - left oxygen sensor signal lean"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faluty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x05</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="89" idhash="0xDE6A0130" title="Code 43 - left oxygen sensor signal rich"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x05</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="90" idhash="0xDE68F450" title="Code 44 - right oxygen sensor signal lean"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x06</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="91" idhash="0xDE68FA10" title="Code 45 - right oxygen sensor signal rich"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x06</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="92" idhash="0xDE68E0B0" title="Code 46 - right to left bank fueling imbalance"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x06</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="93" idhash="0xDE68FFB0" title="Code 47 - BCM-ECM data problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x06</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="94" idhash="0xDE68FDB0" title="Code 48 - EGR szstem fault"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x06</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="95" idhash="0xDE68EAD0" title="Code 49 - A.I.R. management system fault"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x06</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="96" idhash="0xDE68E970" title="Code 50 - 2nd gear press. dis. open/short"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x06</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="97" idhash="0xDE68F330" title="Code 51 - EPROM checksum mismatch"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x06</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="111" idhash="0xCD53CF7B" title="Code 52 - ECM memory reset"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x07</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="112" idhash="0xCD53D5DB" title="Code 53 - distributor signal interrupt"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x07</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="114" idhash="0xCD53C8DB" title="Code 54 - ISC system problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x07</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="115" idhash="0xCD53DFBB" title="Code 55 - TPS out of adjustment"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x07</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="116" idhash="0xCD53DC1B" title="Code 58 - VATS malfunction"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x07</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="119" idhash="0xCD53DC5B" title="Code 60 - C/C transmission not in drive"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x08</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="120" idhash="0xCD50953B" title="Code 61 - C/C transmission not in drive"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x08</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="121" idhash="0xCD509B7B" title="Code 62 - C/C vacuum solenoid problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x08</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="124" idhash="0xCD509CDB" title="Code 63 - C/C car speed and set speed difference too high"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x08</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="125" idhash="0xCD508BBB" title="Code 64 - C/C vehivle acceleration to high"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x08</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="126" idhash="0xCD50881B" title="Code 65 - C/C servo position sensor failure"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x08</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="127" idhash="0xCD50925B" title="Code 66 - C/C engine rpm to high"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x08</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="128" idhash="0xCD509F1B" title="Code 67 - C/C switch enabled to long"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x08</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="129" idhash="0xCD50885B" title="Code 68 - C/C servo stroke to large"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x09</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="130" idhash="0xCD53753B" title="Code 69 - traction control active while in cruise"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x09</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="131" idhash="0xCD537B7B" title="Code 70 - intermittent throttle position"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x09</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="132" idhash="0xCD5361DB" title="Code 71 - intermittent MAP"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x09</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="133" idhash="0xCD537EDB" title="Code 74 - intermittent MAT"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x09</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="134" idhash="0xCD537CDB" title="Code 75 - intermittent VSS"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x09</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="135" idhash="0xCD536BBB" title="Code 80 - fuel system rich"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0A</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="136" idhash="0xCD53681B" title="Code 90 - brake input problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0B</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="137" idhash="0xCD53725B" title="Code 91 - P/N or PRND321 input problem"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0B</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="138" idhash="0xCD537F1B" title="Code 92 - heated windshield request present too long"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0C</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="139" idhash="0xCD53685B" title="Code 95 - engine stall detected"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0C</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="140" idhash="0xCD53353B" title="Code 96 - torque converter overstressed"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0C</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="141" idhash="0xCD533B7B" title="Code 97 - P/N to D/R at high throttle angle"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0C</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="142" idhash="0xCD5321DB" title="Code 98 - P/N to D/R at high rpm in ISC range"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0C</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="143" idhash="0xCD533EDB" title="Code 99 - C/C servo stroke high - not in cruise"> <flags>0x00000004</flags> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>faulty</truestring> <falsestring>ok</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x0C</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="0" idhash="0x86F35ADB" title="2nd gear pressure"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>present</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x20</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="78" idhash="0xDE6BBE70" title="3rd gear status"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>in 3rd</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x20</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="144" idhash="0xCD533CDB" title="4th gear status"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>in 4th</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x20</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="113" idhash="0xCD53CADB" title="P/N status"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>P/N</truestring> <falsestring>D/R</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x20</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="77" idhash="0xDE6BB330" title="VCC status"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>energized</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x20</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="79" idhash="0xDE6BA930" title="throttle switch"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>closed</truestring> <falsestring>open</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x20</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="80" idhash="0xDE6A1C50" title="actual brake switch"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>closed</truestring> <falsestring>open</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x20</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="148" idhash="0xCD533F1B" title="P park"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>P</truestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x26</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="149" idhash="0xCD53285B" title="R reverse"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>R</truestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x26</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="150" idhash="0xCD51D93B" title="N neutral"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>N</truestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x26</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="151" idhash="0xCD51D77B" title="4 Drive"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>D</truestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x26</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="152" idhash="0xCD51CDDB" title="3 Drive"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>3</truestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x26</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="153" idhash="0xCD51D2DB" title="2 Drive"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>2</truestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x26</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="154" idhash="0xCD51D0DB" title="1 Drive"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>1</truestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x26</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="46" idhash="0xDE6A7970" title="cruise control status"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>on</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x21</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="73" idhash="0xDE6BBFB0" title="cruise control enable"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>enabled</truestring> <falsestring>disabled</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x21</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="43" idhash="0xDE6A6FB0" title="cruise vent solenoid"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>energized</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x21</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="44" idhash="0xDE6A6DB0" title="cruise vacuum solenoid"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>energized</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x21</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="45" idhash="0xDE6A7AD0" title="cruise resume/accel"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>closed</truestring> <falsestring>open</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x21</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="47" idhash="0xDE6A6330" title="cruise set/coast"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>closed</truestring> <falsestring>open</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x21</packetoffset> <operand>0x00000010</operand> <bitop>AND</bitop> <result>0x00000010</result> </ADXBITMASK> <ADXBITMASK id="155" idhash="0xCD51C7BB" title="air switch solenoid"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>energized</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2D</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXBITMASK id="156" idhash="0xCD51C41B" title="air divert solenoid"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>energized</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2D</packetoffset> <operand>0x00000008</operand> <bitop>AND</bitop> <result>0x00000008</result> </ADXBITMASK> <ADXBITMASK id="158" idhash="0xCD51D31B" title="heated windshield"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>on</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2D</packetoffset> <operand>0x00000020</operand> <bitop>AND</bitop> <result>0x00000020</result> </ADXBITMASK> <ADXBITMASK id="159" idhash="0xCD51C45B" title="A/C clutch status"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>on</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2D</packetoffset> <operand>0x00000040</operand> <bitop>AND</bitop> <result>0x00000040</result> </ADXBITMASK> <ADXBITMASK id="160" idhash="0xCD51AD3B" title="power steering pressure"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>present</truestring> <falsestring>off</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2D</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="161" idhash="0xCD51A37B" title="current ALDL mode 0"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>yes</truestring> <falsestring>no</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2E</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="162" idhash="0xCD51B9DB" title="current ALDL mode 1"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>yes</truestring> <falsestring>no</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2E</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="163" idhash="0xCD51A6DB" title="current ALDL mode 7"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>yes</truestring> <falsestring>no</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2E</packetoffset> <operand>0x00000080</operand> <bitop>AND</bitop> <result>0x00000080</result> </ADXBITMASK> <ADXBITMASK id="164" idhash="0xCD51A4DB" title="current ALDL mode 8"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>yes</truestring> <falsestring>no</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2F</packetoffset> <operand>0x00000001</operand> <bitop>AND</bitop> <result>0x00000001</result> </ADXBITMASK> <ADXBITMASK id="165" idhash="0xCD51B3BB" title="current ALDL mode 9"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>yes</truestring> <falsestring>no</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2F</packetoffset> <operand>0x00000002</operand> <bitop>AND</bitop> <result>0x00000002</result> </ADXBITMASK> <ADXBITMASK id="166" idhash="0xCD51B01B" title="current ALDL mode 10"> <parentcmdidhash>0x00000000</parentcmdidhash> <truestring>yes</truestring> <falsestring>no</falsestring> <ALARMONSET color="0x000000FF" /> <ALARMONNOTSET color="0x0000FF00" /> <packetoffset>0x2F</packetoffset> <operand>0x00000004</operand> <bitop>AND</bitop> <result>0x00000004</result> </ADXBITMASK> <ADXLISTVIEW id="DEFAULTVIEW" idhash="0x38ADC566" title="Default View"> <entrycount>131</entrycount> <ADXLVENTRY entrytype="0" itemidhash="0x86F34E3B" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A9730" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A9A70" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A8D30" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A9BB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A8D70" /> <ADXLVENTRY entrytype="0" itemidhash="0x86F347BB" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A9050" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE69D970" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE69D930" /> <ADXLVENTRY entrytype="0" itemidhash="0x86F3513B" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE69DAD0" /> <ADXLVENTRY entrytype="0" itemidhash="0x86F350FB" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A9E10" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A84B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A2450" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A2A10" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A2330" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE69C450" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE69CA10" /> <ADXLVENTRY entrytype="0" itemidhash="0x86F3533B" /> <ADXLVENTRY entrytype="0" itemidhash="0x86F3445B" /> <ADXLVENTRY entrytype="0" itemidhash="0x86F347FB" /> <ADXLVENTRY entrytype="0" itemidhash="0x86F35DBB" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A2E70" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE69CDB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A30B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A2FB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A3930" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A2DB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A3AD0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A3970" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53CB1B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53C65B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD532BBB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51DE5B" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68FC50" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE689530" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE688270" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE688F30" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A6E70" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A7930" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE688850" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6883B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6881B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6896D0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68E8B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68F7B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68F5B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68E2D0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68E170" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68FB30" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68F670" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68E130" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6BBDB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6BAAD0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A08B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A17B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A15B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A02D0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A0170" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A1B30" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A1670" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A0130" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68F450" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68FA10" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68E0B0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68FFB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68FDB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68EAD0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68E970" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE68F330" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53CF7B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53D5DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53C8DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53DFBB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53DC1B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53DC5B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD50953B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD509B7B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD509CDB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD508BBB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD50881B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD50925B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD509F1B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD50885B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53753B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD537B7B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD5361DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD537EDB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD537CDB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD536BBB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53681B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53725B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD537F1B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53685B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53353B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD533B7B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD5321DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD533EDB" /> <ADXLVENTRY entrytype="0" itemidhash="0x86F35ADB" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6BBE70" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD533CDB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53CADB" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6BB330" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6BA930" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A1C50" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD533F1B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD53285B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51D93B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51D77B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51CDDB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51D2DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51D0DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A7970" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6BBFB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A6FB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A6DB0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A7AD0" /> <ADXLVENTRY entrytype="0" itemidhash="0xDE6A6330" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51C7BB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51C41B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51D31B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51C45B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51AD3B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51A37B" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51B9DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51A6DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51A4DB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51B3BB" /> <ADXLVENTRY entrytype="0" itemidhash="0xCD51B01B" /> </ADXLISTVIEW> </ADXFORMAT>
03:14 AM
lou_dias Member Posts: 5382 From: Warwick, RI Registered: Jun 2000
If you are scanning and you notice the settings jump around do a search for Phonedawgz "how to" videos because you have to change a setting in the ADX file to eliminate it. Do a darn search...don't bother messaging him.
03:16 AM
03:21 AM
MadProfessor8138 Member Posts: 351 From: Ekron,Kentucky Registered: May 2015
lou_dias......I found the videos on YouTube after you first mentioned that they existed.....I have looked at a few of them but I just haven't had time to study all of them yet.....life is busy with the responsibilities of an adult life unfortunately. While I absolutely appreciate any help you are willing to give,you need to realize that not everyone is as up to date with computers as the next guy. We are all here to help each other........
09:39 AM
Apr 13th, 2017
gen2muchwork Member Posts: 861 From: dearborn, MI Registered: Feb 2012
Ok, I have been super busy. I have a long weekend coming up and will try to get the laptop up and scanning to provide some info.
The big problem is that RT can do so much, and there is a lot of info out there. Unfortunately, that can be overwhelming and our 4.9 can only use a tiny portion of what is available in the software. I get it.
I see what lou posted, and really I have no idea what all that code is, although I suspect it's the same thing I use, just "out of the file". I'm sure it's helpful stuff, but that's over my head. Still, if I can manage to scan this thing without understanding alll that... So can you.
I'm sure I can email you the adx I use if you are having trouble locating it once I get around to it.
[This message has been edited by gen2muchwork (edited 04-13-2017).]
09:26 AM
fierosound Member Posts: 15249 From: Calgary, Canada Registered: Nov 1999
Rather than going thru the trouble of PM'ing everyone then emailing everyone a file individually, I opened the .adx file in Notepad and copied and pasted the contents of it into the message. All you have to do is copy and paste it into your own file with whatever name you choose as long as it ends with .adx then you can open that file with Tuner Pro and start scanning your 4.9...
09:53 AM
Lou_dias.......I figured that was the file that you posted.
The CD that I received with the cable and program has files on it....I was just having a hard time figuring out which was the proper file to load into the program.
Will give your file a shot this weekend,thanks for posting it.
Been a busy week,I have my kiddo,and I just haven't had any time to get in the garage this week.
[This message has been edited by MadProfessor8138 (edited 04-13-2017).]
06:31 PM
