On the tank is nothing many times.
Rust where straps hold up is a bigger problem.
Water and salt eat thru those areas often.
No leak then bush off big rust and use whatever. Many Want some rust to work.
Leaks then get a new/better tank for most people.
Repair w/ epoxy often fails and soon. Wrong kind can ruin the fuel pump etc And leak too.
DIY should Not solder them because....
Warning: Solder heat + gas and fumes often = Boom. Heat can damage/ruin the plastic baffler etc.
Many are hurt or killed soldering because of gas fumes or use wrong solder and leak again.
(Jurassic Park)The Ogre's Fiero Cave[This message has been edited by theogre (edited 10-01-2016).]
